HumbleChief Posted Friday at 03:42 PM Share Posted Friday at 03:42 PM I think I understood this at one time but am a bit baffled by the behavior today. Each measurement in the pic is set to a whole number measurement but each measurement has an added 1/2" when finally displayed. Doesn't present a genuine problem in this case but could in a different context. Any help appreciated. ...and it only happens in this room. THANK YOU Link to comment Share on other sites More sharing options...
winterdd Posted Friday at 03:44 PM Share Posted Friday at 03:44 PM 1 minute ago, HumbleChief said: I think I understood this at one time but am a bit baffled by the behavior today. Each measurement in the pic is set to a whole number measurement but each measurement has an added 1/2" when finally displayed. Doesn't present a genuine problem in this case but could in a different context. Any help appreciated. THANK YOU I share your pain on this and interested to hear feedback. Link to comment Share on other sites More sharing options...
DBCooper Posted Friday at 04:22 PM Share Posted Friday at 04:22 PM Could be lots of different things such as your dimensions going to the drywall instead of the framing. But if I was to make a guess, I would bet that it has to do with how you are rounding your dimensions and how accurate you laid out your walls. Your picture is not really enough to tell what is going on. Post your plan. 1 1 Link to comment Share on other sites More sharing options...
JiAngelo Posted Friday at 04:22 PM Share Posted Friday at 04:22 PM I think you need to check your wall locations. Circle 1 wall without drywall matches up with exterior finish material (NOT interior drywall) Circle 2 wall without drywall matches up with interior drywall (NOT exterior finish material) Second, you are missing some necessary measurements to make a proper comparison. Extend and find out the distance from 11' 8-1/2" to interior drywall of left wall (to compare with 14' 8-1/2" measurement. Do this with other locations, like the 6' 8" and 9' 6-1/2" measurements. I think you will find you are mixing/measuring interior layer (drywall) to main layer (stud) in several areas. 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted Friday at 04:49 PM Author Share Posted Friday at 04:49 PM Thanks and maybe to the theories but, as I always do, I select a wall, type in the measurement as in i.e. 11' - 8" then hit enter and the measurement shows as 11' - 8 1/2" - and only in this room? Have this happen and explained in the past but can't remember why Chief will sometimes behave this way. Has some thing to do with rounding algorithms? Dunno. Will post the plan Link to comment Share on other sites More sharing options...
HumbleChief Posted Friday at 04:53 PM Author Share Posted Friday at 04:53 PM Plan File https://www.dropbox.com/scl/fi/9zodnj1oqzs7lp0p237p8/HALF-INCH-ADDED.plan?rlkey=uwj3jys74jstjtg41jrvba3o6&dl=0 Link to comment Share on other sites More sharing options...
HumbleChief Posted Friday at 06:39 PM Author Share Posted Friday at 06:39 PM Interesting? Link to comment Share on other sites More sharing options...
JiAngelo Posted Friday at 06:54 PM Share Posted Friday at 06:54 PM Larry, Thanks for posting the plan. I was wrong about your walls. Your interior wall has the stud wall painted white. Only the number 1 wall was off, but you fixed it in the uploaded plan. In your video, when you are fixing that wall, at the 1:20 mark you point to DIM 12' 5-1/2", click on it, and it reads 12' 5 7/16", to which you then state "that's close enough." Well, it isn't unless you decided to allow precision to be off or round itself in the defaults somewhere. While visiting your default dimensions "ANNO FLOOR PLAN" I saw it was set to Grid rounding - and I think that explains what you are demonstrating in your second video. It is like your walls weren't drawn on the grid initially. Click on Primary Format and you will see it is set for accuracy 1/2. I changed this to 1/16 and here's what your dimensions immediately turned into. To fix this, just change these two walls. The exterior wall with 3 windows, make that dimension 10' 1/2" The closet wall, change that dimension to 2' 6-1/2" You can check all your other dimensions but they should be correct now. 2 Link to comment Share on other sites More sharing options...
HumbleChief Posted Friday at 07:16 PM Author Share Posted Friday at 07:16 PM Thanks for the reply John. I have my primary dimensions to default to 1/2" because I don't want anything more accurate than that in my plans hence 12 - 5 7/16" is indeed close enough - for me. And YES it was the grid rounding setting that was causing the issue (I kinda remember that from the past now). Will probably never understand that but don't really need to and will change the setting going forward. And again thanks very much for taking the time to look over the plan! Link to comment Share on other sites More sharing options...
basketballman Posted Friday at 07:21 PM Share Posted Friday at 07:21 PM Primary dimension format set to 0 will avoid this ... Link to comment Share on other sites More sharing options...
JiAngelo Posted Friday at 08:24 PM Share Posted Friday at 08:24 PM Larry, change your General Plan Defaults snap unit to 1/2" before drawing should keep you on your grid rounding. To test this I drew a random rectangular polyline which measured 2'9" x 3' in your original plan file. I added dimensions with a 1/16 precision to show you what was actually drawn was quite different from what your original dimension defaults showed. Here I also discovered that Chief doesn't round up at 2'8 3/4", it rounds down to 2'8 1/2" And Bob, what you suggested is only better at hiding it. Changing accuracy to 1/0 reverts to 1/1 and then only displays whole numbers. It rounds 2'8 1/2" to 2'8" and 2' 8 17/32" to 2'9 Here's a comparison of all three precision methods. With less precision the errors can compound over farther distances. Notice 1/2" precision has a rounding error occurring between 5/8" and 3/4" And 1/1" precision has a rounding error alternately occurring between each of the 2' 8-5/8" measurements. One measures 2'9" the other 2'8" I'm pretty sure all of this traces back to the 1/16" grid this plan file was drawn on. Link to comment Share on other sites More sharing options...
HumbleChief Posted 8 hours ago Author Share Posted 8 hours ago Thanks again John but 'the reference grid' and grid snap units are two different thing to my understanding and I use the snap units to nudge and locate objects small amounts. The 1/2" simply wouldn't work for me. To quote you "I'm pretty very sure all of this traces back to the 1/16" grid grid rounding this plan file was drawn on" and thanks for your help in discovering that info. Link to comment Share on other sites More sharing options...
para-CAD Posted 33 minutes ago Share Posted 33 minutes ago Is this a clean plan or did you have other walls near there that have since been deleted? I've seen ghost walls do crazy things sometimes. Link to comment Share on other sites More sharing options...
