Cadwork22 Posted August 22, 2024 Share Posted August 22, 2024 I need to create a small Mezzanine in the garage -20' walls in garage. Do you use railings or perhaps a second floor? Thanks in advance Michael Link to comment Share on other sites More sharing options...
Cadwork22 Posted August 22, 2024 Author Share Posted August 22, 2024 If I try drawing a small Mezzanine as a second floor, this is what happens... Link to comment Share on other sites More sharing options...
TeaTime Posted August 22, 2024 Share Posted August 22, 2024 Check out https://www.chiefarchitect.com/support/article/KB-03012/creating-a-storage-loft-in-a-larger-room.html 1 Link to comment Share on other sites More sharing options...
TeaTime Posted August 22, 2024 Share Posted August 22, 2024 Not really sure, its hard to tell from just a photo. Would definitely help to see the plan file. Link to comment Share on other sites More sharing options...
Cadwork22 Posted August 23, 2024 Author Share Posted August 23, 2024 Anything helps, much appreciated. Devin.zip Link to comment Share on other sites More sharing options...
rgardner Posted August 23, 2024 Share Posted August 23, 2024 Yes you need a second floor in that portion of the building. Link to comment Share on other sites More sharing options...
Michael_Gia Posted August 23, 2024 Share Posted August 23, 2024 21 hours ago, Cadwork22 said: I need to create a small Mezzanine in the garage -20' walls in garage. Do you use railings or perhaps a second floor? Thanks in advance Michael Easiest way is to draw a landing from the stair tool and add railings to the sides that need railings. You can add stairs to your mezzanine as well and they behave as they should. 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted August 23, 2024 Share Posted August 23, 2024 3 hours ago, rgardner said: Yes you need a second floor in that portion of the building. why would you say he needs a second floor there? Link to comment Share on other sites More sharing options...
Cadwork22 Posted August 23, 2024 Author Share Posted August 23, 2024 Also, Sky lights aren’t showing in the window schedule, any ideas?? Link to comment Share on other sites More sharing options...
Solution DBCooper Posted August 23, 2024 Solution Share Posted August 23, 2024 You might need to open the schedule and check the box to include skylights. They don't get included automatically by default. 1 Link to comment Share on other sites More sharing options...
Cadwork22 Posted August 24, 2024 Author Share Posted August 24, 2024 Nice, thank you. Link to comment Share on other sites More sharing options...
rgardner Posted August 27, 2024 Share Posted August 27, 2024 On 8/23/2024 at 1:00 PM, Michael_Gia said: why would you say he needs a second floor there? Ever try showing framing of a landing for construction documents? Granted depending on the need of the OP he may just be trying to render it which means that he can use a landing. However if he needs to do anything else with it then a second floor for that portion will be much easier. Link to comment Share on other sites More sharing options...
