GeneDavis Posted August 21 Share Posted August 21 My out-of-box X16 walls, interior and exterior (like Siding-6) walls have materials set as "Drywall" as default. So the walls are a color, a material named "Drywall." And the material reports to material lists in sheets with sizes like 1/2 x 54 x 144. There is no thin paint layer. What is best practice for painting walls? Link to comment Share on other sites More sharing options...
robdyck Posted August 21 Share Posted August 21 Painting them will not affect the materials list, unless you edit the components tab of a room. Assuming you want a room painted the same on all its walls, you can paint walls in 'room mode' or edit the wall material by opening the room specification dialog. I don't like adding material regions or custom backsplashes anywhere other than where very necessary to prevent the plan from slowing down. The same for unnecessary wall layers; I wouldn't recommend adding a wall layer for paint unless you know of a specific reason to. Link to comment Share on other sites More sharing options...
MPDesign Posted August 21 Share Posted August 21 In your default wall type. I like to add a 0" thick layer inside the drywall, set to the paint color of your choice. I think it should report as square feet in a material list. and other ways I'm sure Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 21 Share Posted August 21 Material Regions work very well. You can even create stripes, etc. Link to comment Share on other sites More sharing options...
