Decor: what's best practice for painting interior walls
GeneDavis
My out-of-box X16 walls, interior and exterior (like Siding-6) walls have materials set as "Drywall" as default.
So the walls are a color, a material named "Drywall."  And the material reports to material lists in sheets with sizes like 1/2 x 54 x 144.
There is no thin paint layer.
What is best practice for painting walls?
Painting them will not affect the materials list, unless you edit the components tab of a room.
Assuming you want a room painted the same on all its walls, you can paint walls in 'room mode' or edit the wall material by opening the room specification dialog.
I don't like adding material regions or custom backsplashes anywhere other than where very necessary to prevent the plan from slowing down.
The same for unnecessary wall layers; I wouldn't recommend adding a wall layer for paint unless you know of a specific reason to.
