Auto-Filling Wall Tops Under Exposed Rafter Tails?
HumbleChief
Go to solution Solved by Gawdzira,
By setting the sub-fascia to 0 it may cut off the beams from showing so you then have to manually place the overhang beams. I remember a time when it worked well but it may have been a long time ago. doing good Larry, just working, but not as much as I use to. slowed down a bit.
  On 8/20/2024 at 4:00 PM, HumbleChief said:
Thanks P, hope you're doing well! Tried a bunch of options but no love so far. Have t you ever had it work?
Expand
As Allan mentioned Larry for P's trick to work the Soffits must be ON....
Allan's settings
 I think I got it. Soffits have to be active but cheating the eave sub fascia to tiny gets the look.
image.thumb.png.eda91355641dd4056167fa595260a564.pngimage.thumb.png.d1a40636001c001bf5da3fd03625c932.png
  • Upvote 2
