HumbleChief Posted August 20, 2024 Share Posted August 20, 2024 Is there a way to do so other than manually pulling up each wall in 3D? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 20, 2024 Share Posted August 20, 2024 try setting your sub-fascia to "0" 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted August 20, 2024 Author Share Posted August 20, 2024 Thanks P, hope you're doing well! Tried a bunch of options but no love so far. Have t you ever had it work? Link to comment Share on other sites More sharing options...
Solution Gawdzira Posted August 20, 2024 Solution Share Posted August 20, 2024 I just had a conversation with myself about this 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 20, 2024 Share Posted August 20, 2024 By setting the sub-fascia to 0 it may cut off the beams from showing so you then have to manually place the overhang beams. I remember a time when it worked well but it may have been a long time ago. doing good Larry, just working, but not as much as I use to. slowed down a bit. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted August 20, 2024 Share Posted August 20, 2024 2 hours ago, HumbleChief said: Thanks P, hope you're doing well! Tried a bunch of options but no love so far. Have t you ever had it work? As Allan mentioned Larry for P's trick to work the Soffits must be ON.... Allan's settings Posted July 19 I think I got it. Soffits have to be active but cheating the eave sub fascia to tiny gets the look. 2 Link to comment Share on other sites More sharing options...
HumbleChief Posted August 20, 2024 Author Share Posted August 20, 2024 THANK YOU SO MUCH!!! Struggled with that forever!!! Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 20, 2024 Share Posted August 20, 2024 thanks k-Bird for that important info. I guess I forgot that, but my soffits are always on. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted August 20, 2024 Share Posted August 20, 2024 1 hour ago, DRAWZILLA said: thanks k-Bird for that important info. I guess I forgot that, but my soffits are always on. Allan had already mentioned it so there was no need to re-write it , so this one goes to Him M. 1 Link to comment Share on other sites More sharing options...
