Parking Lot
Cadwork22
Go to solution Solved by GeneDavis,
If you are good with the road and parking lot being the same material, I typically start with a polyline road and draw out the complete perimeter of the parking area and roads connecting it.  Then I add medians as needed for islands.  For example, if you parking lot goes all the way around your building, then the building will be on a large median.  Your median may even form once side of a road depending on how your parking lot is configured.
  • Solution
44 minutes ago, Cadwork22 said:
I used the rectangle tool and filled it asphalt material, however having difficulties putting parking lines. How did you do this?
More CAD polylined, color fill, and learn to use the order of draw tools.  Use Chief's Help files to learn.
