westvale Posted June 25, 2024 Share Posted June 25, 2024 Hi friends, Every time I run an interior ray trace, they're always very dark. This interior has tons of windows and light fixtures, and it's still dark! How do I fix this? Link to comment Share on other sites More sharing options...
Designers_Ink Posted June 25, 2024 Share Posted June 25, 2024 Can you post the .plan file so we an see your lighting, sun and camera settings? Link to comment Share on other sites More sharing options...
JLU_Design Posted June 25, 2024 Share Posted June 25, 2024 My guess is you may want to adjust your exposure. 1 Link to comment Share on other sites More sharing options...
westvale Posted June 25, 2024 Author Share Posted June 25, 2024 1 hour ago, Designers_Ink said: Can you post the .plan file so we an see your lighting, sun and camera settings? I've never done it before... it's telling me the file is too big. I'll share a screenshot. Link to comment Share on other sites More sharing options...
westvale Posted June 25, 2024 Author Share Posted June 25, 2024 1 hour ago, JLU_Design said: My guess is you may want to adjust your exposure. JLU_Design thank you! I wasn't aware of this setting and it's making all the difference! I'm so grateful for your suggestion! Link to comment Share on other sites More sharing options...
Gawdzira Posted June 26, 2024 Share Posted June 26, 2024 Drop your daytime backdrop levels to about 300. Change your sun intensity to about 400 and then you might want to add some general lighting (light sources) with shadows off. I tend to scatter those around to fill in dark zones (lower cabinet faces...) Make sure to check in your camera how many lights can be used. Bump that number up as it defaults to a pretty low number if you have lights in a full house as opposed to only one room (44? may be the default) If you use a backdrop, it will really affect your light color. I tend to drop the recessed light to about 200 and take the color very slightly yellow so they don't glow around the edges 1 Link to comment Share on other sites More sharing options...
Vayahog Posted June 26, 2024 Share Posted June 26, 2024 Make your lights more powerful Link to comment Share on other sites More sharing options...
dskogg Posted June 27, 2024 Share Posted June 27, 2024 I use 3000 for daytime and .4 for exposure...works great, try that. Also I always adjust sun using move sun option to bring sunlight into model. Link to comment Share on other sites More sharing options...
Mark3D Posted June 27, 2024 Share Posted June 27, 2024 On 6/26/2024 at 8:09 AM, westvale said: I've never done it before... it's telling me the file is too big. I'll share a screenshot. try zip or compress the file see if that gets it below 14meg right click the file compress to zip file Link to comment Share on other sites More sharing options...
