to generate Auto Roof set to Pitch independently.
buzzsaw204
Go to solution Solved by glennw,
19 minutes ago, DRAWZILLA said:
look in the wall DBX, there you can add any pitch you want different than the default on a wall-by-wall basis.
yes, you can set each wall to different pitch.
But when you auto generate the roof, the opposite side steel takes the pitch of the main roof.
Even if you break the wall, and assigned it a different pitch.
Have you tried room dividers at the breaks so that Chief sees 3 different rooms defined?
Then try changing the middle room to roof group 1.
But I have to ask how you intend to deal with eaves on the long side?  You need the planes to start off at the same facia plane, not the heel height.
  • Upvote 2
John's suggestion is the best solution for now...may have to tweak manually...or drawing it manually would be pretty fast...can quickly modify any of the initial auto roofs pretty quickly.
