Cadwork22 Posted April 3 Share Posted April 3 I need to adjust the angle of two walls, and the angle dimensions is doing nothing, I read in the forums to use CAD lines, and still nothing. Any thoughts? Thanks, Link to comment Share on other sites More sharing options...
Solution para-CAD Posted April 3 Solution Share Posted April 3 can you open object on the wall you want to change and manually enter the angle you want? Link to comment Share on other sites More sharing options...
Cadwork22 Posted April 3 Author Share Posted April 3 great thanks Link to comment Share on other sites More sharing options...
Gawdzira Posted April 3 Share Posted April 3 CAD lines as a reference to use the make parallel tool. You might have to temporarily disconnect the wall from the other wall to get it to move properly. Link to comment Share on other sites More sharing options...
DBCooper Posted April 3 Share Posted April 3 You should be able to use an angular dimension as well. You have to draw the angular dimension manually, then select the wall you want to rotate, and then click on the angle to change it. Works basically the same way that moving a wall by clicking on a normal dimension works. 1 Link to comment Share on other sites More sharing options...
Gawdzira Posted April 3 Share Posted April 3 I don't do this much but noticed that the start point of the wall "S" is the rotation point and will then disconnect from the end point if you adjust with the angle in the dbx. Therefore, make sure the start and end points are on the correct side. Link to comment Share on other sites More sharing options...
DBCooper Posted April 3 Share Posted April 3 You can also use the "lock" to control how it rotates or moves when you make changes in the wall dialog. It does help to pay attention to the start and end though. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted April 3 Share Posted April 3 2 hours ago, Gawdzira said: make sure the start and end points are on the correct side And turned ON in Preferences too......not sure it on by Default? 1 Link to comment Share on other sites More sharing options...
