stevenyhof Posted April 3 Author Share Posted April 3 13 minutes ago, Kbird1 said: Auto framing can slow things down (especially if a Schedule is used?) as can Fills with huge numbers of CAD lines too. I do not have auto framing on, and rarely use framing. I think I did use framing on this house though if I remember correctly. Link to comment Share on other sites More sharing options...
stevenyhof Posted April 3 Author Share Posted April 3 10 minutes ago, Renerabbitt said: just had to use zoom and shared my screen..abysmal performance..glad I dont use that anymore, haha I checked out streamyard, but is it simple for non video conferencing people to connect on their end? Seems it needs to be done in a browser and depending on their devise, what browser is best to use. Have you run into any issues with that? Link to comment Share on other sites More sharing options...
Renerabbitt Posted April 3 Share Posted April 3 32 minutes ago, stevenyhof said: I checked out streamyard, but is it simple for non video conferencing people to connect on their end? Seems it needs to be done in a browser and depending on their devise, what browser is best to use. Have you run into any issues with that? it doesnt have some features of zom, but easy to work with and yes just runs through a browser and they keep adding features Link to comment Share on other sites More sharing options...
stevenyhof Posted April 3 Author Share Posted April 3 3 minutes ago, Renerabbitt said: it doesnt have some features of zom, but easy to work with and yes just runs through a browser and they keep adding features I don't use features. The client and I are talking and watching my screen and I point things out. I did get "Region to Share" - a small piece of software so you can show only a part of my screen - that is very nice. Zoom has that built in, but most do not. Outside of that, I do not use drawing tools, etc. So it can be a very simple system. Link to comment Share on other sites More sharing options...
stevenyhof Posted April 4 Author Share Posted April 4 On 4/1/2024 at 10:02 AM, robdyck said: All the window panes are intact...shouldn't some be broken and others very dirty?! Just kidding of course, what you've done with that image is pretty amazing! So, what you think of this broken glass? About 10 mins work just to see how it may look Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 4 Share Posted April 4 need it on a non covered wall to see it better Link to comment Share on other sites More sharing options...
stevenyhof Posted April 4 Author Share Posted April 4 On 4/4/2024 at 6:11 PM, SHCanada2 said: need it on a non covered wall to see it better Its not very nice in the window. I just wanted to figure it out. The window is insulated air to blank out the glass and the broken glass are solids turned into glass. If you put the sunlight on the floor the glass turns black and unimpressive. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted April 6 Share Posted April 6 On 4/4/2024 at 1:55 PM, stevenyhof said: So, what you think of this broken glass? Like Jason said it's a little hard to see what's going on. The glass on the porch floor looks better than the glass that is/is not in the window. I think it will look better if the individual panes are broken rather than a big section of the glass missing across multiple panes. Be sure to add some spiderwebs and cobwebs in the corners of some of the panes. Your textures are looking great except that the grain is running the wrong way on the horizontal window muntins. (hate when that happens) Keep up the good work! Really like what you are doing by trying to get the best possible output from the tools Chief supplies instead of just telling everyone to use some different software programs for renderings. I had to go back to X6 to find this broken window I had a play with. As I recall I set the window glass to no material and made the broken pane from a thin 3D solid set to the standard glass material. Link to comment Share on other sites More sharing options...
stevenyhof Posted April 6 Author Share Posted April 6 6 hours ago, Rich_Winsor said: Keep up the good work! Thank you, Rich! I could make everything flawless if I wanted, but I mainly wanted to prove to myself and others that Chief has the tools to do a great job with rendering. Here is a modern home I drew and just completed the construction docs. Then I spent two hours making a rendering. Spent an hour just messing with backdrops, and lighting inside and out. One thing I am learning, and that is that with the simple method I am proposing at the start of this forum thread, a nice looking rendering can be done quit fast. But when you start to mess with photo backgrounds to attempt to make the whole image look real, the lighting and backdrop hue causes a very individualized camera experience. House designed by BD/DSGN Years old fake plants by Chief 1 Link to comment Share on other sites More sharing options...
para-CAD Posted April 9 Share Posted April 9 Amazing work, Steve. Thanks for all the work you have into this and for sharing! 1 2 Link to comment Share on other sites More sharing options...
stevenyhof Posted April 9 Author Share Posted April 9 29 minutes ago, para-CAD said: Amazing work, Steve. Thanks for all the work you have into this and for sharing! Thank you, Sir! It's been a lot of fun to learn rendering and now being able to do it within Chief. Link to comment Share on other sites More sharing options...
stevenyhof Posted May 30 Author Share Posted May 30 Rendering Materials and Libraries Update for X16... I am putting together the floor plans and now renderings for a condo project. I am posting this here because this is a continuation of the rendering method I proposed in the beginning of this thread. I am using this method to render some of my projects. I needed to put together 5 renderings, and while the first took about 90 minutes, the last two renderings were done in under 45 minutes. As you learn more about Terrain Features, using them to make driveways, sidewalks and landscaping beds, you can begin to set up defaults or parts that can be brought into your model that already have the materials and properties you end up using over and over. The Landscape Library has a few new trees (not Chief) and are larger in file size (Tree01 and Tree02). There are also a number of Hosta plants that are now available to use in X16. The library also has a number of the objects like Grunge, Grade (lawn plants and leaves) and Shadow trees (which I do not use. But if you have a smaller graphics card, they can help with rendering speed.) X16 now supports HDRi backdrop images. I am including a library of some images I put together. HDR08 is what I use now for the "Backdrop" image vs one I made for X15. HDRi images do a better job of creating tree and sky reflections in your windows. X16 Drawing Template I am also including my Template as it includes a number of cameras that you can copy and paste into your templates. https://drive.google.com/file/d/1YAeQKPG87YFoMC9O5Y0-QKWe5EWF_1tT/view?usp=sharing X16 Landscape Library https://drive.google.com/file/d/111cmp7Qe5UIKMqgmQ9rJ_fLWURjj_4eQ/view?usp=sharing X16 HDRi Backdrop Library (used for more realistic backdrops, or for window reflection as I am using them) https://drive.google.com/file/d/1EuUVvrhFGBC4eX5VG54TbrqtAF3dndk9/view?usp=sharing X16 Background Image Library (used for the background images you see in the rendering) https://drive.google.com/file/d/1UIMoHnTTF5t9gnd0F_OjR7d0rfcs5Pbl/view?usp=sharing See the beginning of this thread for rendering method... Thank you, Steve 2 3 Link to comment Share on other sites More sharing options...
