rwaldrondesigns Posted February 23, 2024 Share Posted February 23, 2024 When I put leaders with text on my drawings, the default centers the text vertically with the leader line. What this means is that if I have several notes, it gets muddy and unclear as to what notes belong to what leader. I'd like to update it so that my leader line aligns with the first row of text or the top of the text box, rather than the center. Does anyone know how to do this? thank you!! Link to comment Share on other sites More sharing options...
DBCooper Posted February 23, 2024 Share Posted February 23, 2024 Try clicking on the leader line and dragging the end handle to where you want it. You might need to turn off angle snaps or hold the control key down but you should be able to drag it along the side of the box to put it where you want it. Just make sure that your leader still has a closed circle instead of an open square for the end handle if you want it to stay attached to the text. If this doesn't help, then post a picture of what you are trying to do. Link to comment Share on other sites More sharing options...
JKEdmo Posted February 23, 2024 Share Posted February 23, 2024 19 minutes ago, DBCooper said: Try clicking on the leader line and dragging the end handle to where you want it. I think Rachel is looking for a default setting instead of manual adjustment. I don't think there is one, but could be wrong. 1 Link to comment Share on other sites More sharing options...
rwaldrondesigns Posted February 25, 2024 Author Share Posted February 25, 2024 JKEdmo is right, I'm looking for a default. I did drag them manually, but that's a bit of a nightmare for a large set! 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted February 25, 2024 Share Posted February 25, 2024 @rwaldrondesignswhy not go ahead right now and compose a suggestion that Chief have an option for this? Preferences>Appearance>Text seems like the right place to have it. Something like "Attach leader lines to text at font center first line of block" might be clear enough to understand. Right now the attachment defaults to center of block, and the attachment point can be dragged to snap to block corners and midpoints sides and top and bottom. Your option, if checked, would give you what you want, and also give users an additional snap point for moving the leader attachment point. Link to comment Share on other sites More sharing options...
rwaldrondesigns Posted February 25, 2024 Author Share Posted February 25, 2024 6 hours ago, GeneDavis said: @rwaldrondesignswhy not go ahead right now and compose a suggestion that Chief have an option for this? Preferences>Appearance>Text seems like the right place to have it. Something like "Attach leader lines to text at font center first line of block" might be clear enough to understand. Right now the attachment defaults to center of block, and the attachment point can be dragged to snap to block corners and midpoints sides and top and bottom. Your option, if checked, would give you what you want, and also give users an additional snap point for moving the leader attachment point. Just to confirm, you're saying this as a hypothetical, not as something that currently exists? Link to comment Share on other sites More sharing options...
GeneDavis Posted February 26, 2024 Share Posted February 26, 2024 Suggest it. Be clear. It ain't there in X15 Link to comment Share on other sites More sharing options...
MoeGia Posted February 26, 2024 Share Posted February 26, 2024 Plus one. I would prefer to set my arrow attachments to the first line as well. Link to comment Share on other sites More sharing options...
