Larry_Sweeney Posted February 11, 2024 Share Posted February 11, 2024 What determines the 2D Symbol size and text spacing between lines in Note Schedules? Shown in my attachment are two note schedules and you can clearly see the differences I'm talking about. I've compared the dbx. between the two and I can't find any differences or where I can set them up so they would look alike for the 2D Symbol size and correct spacing between lines. I attempted searches but didn't find anything on the subject I was looking for. What am I missing or where should I be looking? As always, any help is greatly appreciated. Link to comment Share on other sites More sharing options...
DBCooper Posted February 12, 2024 Share Posted February 12, 2024 Open the note schedule and take a look at the "object preview options". Are both schedules set to "use plan view scale"? If so then they should be the same size and the size comes from the size of the notes in your plan. If they are not, then the size comes from the column width which also determines the row size. If this doesn't help, then you probably need to post the plan. Link to comment Share on other sites More sharing options...
robdyck Posted February 12, 2024 Share Posted February 12, 2024 On 2/11/2024 at 10:41 AM, Larry_Sweeney said: Shown in my attachment are two note schedules and you can clearly see the differences I'm talking about. The spacing is increased in the longer schedule because the callouts are larger for numbers with 2 digits. Spacing is based on the largest symbol shown. Make over a hundred notes to see what's happening. 3 Link to comment Share on other sites More sharing options...
robdyck Posted February 12, 2024 Share Posted February 12, 2024 An optional solution to this spacing is to use a Rectangle as the text note callout. Link to comment Share on other sites More sharing options...
TeaTime Posted February 12, 2024 Share Posted February 12, 2024 5 hours ago, robdyck said: ... 2 hours ago, robdyck said: ... Please tell me you weren't playing with Notes for 3-4 hrs. 1 Link to comment Share on other sites More sharing options...
robdyck Posted February 13, 2024 Share Posted February 13, 2024 38 minutes ago, TeaTime said: Please tell me you weren't playing with Notes for 3-4 hrs. I did have to change the callout labels on over a hundred notes. That takes time my friend! 1 Link to comment Share on other sites More sharing options...
Solution Larry_Sweeney Posted February 14, 2024 Author Solution Share Posted February 14, 2024 Thanks to all for your responses. All where helpful in understanding "my" problem and not CA's. Have a great day. Link to comment Share on other sites More sharing options...
