Tkangas Posted January 10, 2024 Share Posted January 10, 2024 I've been using Chief Architect for 20 years but I still run into challenges. An issue I've been unable to fix is: to make a flat roof thickness match the fascia height. When viewed from below, the soffit appears recessed into the eaves, but it should be flush (or nearly) with bottom of fascia. Unable to attach floor plan. ANY help is greatly appreciated! Chief X15 Windows 11 Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 10, 2024 Share Posted January 10, 2024 Without the plan file it's just a guess but I'd try increasing the gable sub fascia depth. 1 Link to comment Share on other sites More sharing options...
rgardner Posted January 10, 2024 Share Posted January 10, 2024 1 hour ago, Tkangas said: I've been using Chief Architect for 20 years but I still run into challenges. An issue I've been unable to fix is: to make a flat roof thickness match the fascia height. When viewed from below, the soffit appears recessed into the eaves, but it should be flush (or nearly) with bottom of fascia. Unable to attach floor plan. ANY help is greatly appreciated! Chief X15 Windows 11 52 minutes ago, Chrisb222 said: Without the plan file it's just a guess but I'd try increasing the gable sub fascia depth. Should be 12" Link to comment Share on other sites More sharing options...
GeneDavis Posted January 10, 2024 Share Posted January 10, 2024 This roof has a 3:12 pitch and a triple-step fascia, but as can be seen in the structure settings, the gable and eave subfascia settings are different to be able to achieve fascia line matching. Link to comment Share on other sites More sharing options...
JLU_Design Posted January 11, 2024 Share Posted January 11, 2024 23 hours ago, Tkangas said: An issue I've been unable to fix is: to make a flat roof thickness match the fascia height. When viewed from below, the soffit appears recessed into the eaves, but it should be flush (or nearly) with bottom of fascia. The soffit height is controlled by the bottom of the sub-fascia. The top of the finished fascia is is controlled by the bottom on layer# 1 in the Roof Surface Definition dialog. Another thing I do is add a 0" layer at the bottom of the surface definition to trick Chief into building the roof structure correctly. That's how it makes sense to me anyway. Link to comment Share on other sites More sharing options...
Renerabbitt Posted March 27, 2024 Share Posted March 27, 2024 bringing this back from the dead: 240327 (2).mp4 Link to comment Share on other sites More sharing options...
