joey_martin Posted March 19, 2015 Share Posted March 19, 2015 Open the window dbx and click on the framing tab. Link to comment Share on other sites More sharing options...
LeeDrafter Posted March 19, 2015 Share Posted March 19, 2015 Open the window dbx and click on the framing tab. mine doesn't have a framing tab. I am using X5, maybe the framing tab is in a newer version? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 19, 2015 Share Posted March 19, 2015 Yes ,there was no window hdr framing tab in X5. you would have to do it manually by opening up the wall and changing it and checking "retain wall framing". Do it last thing on a plan b/c if there are changes, you would have to do it again. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 19, 2015 Share Posted March 19, 2015 mine doesn't have a framing tab. I am using X5, maybe the framing tab is in a newer version? That's why it is advised to add your Version etc to your Member Profile in the Signature area , as you can see on most of our posts, that way you get the correct answer 1st time around. go upto the RH top corner click on your user name and then my settings to add a sig. M. Link to comment Share on other sites More sharing options...
mthd97 Posted March 20, 2015 Share Posted March 20, 2015 One of the main improvements in X6 was the ability to specify header type and size for openings that don't fit the usual build framing tab to a general opening per width size. You can however in X5 and less as mentioned here open the framing detail and edit the header size or copy to add extra headers to that opening. I have not checked to see if it will report to the ML after you have asked CA to create a new ML after your editing but I think it will after what others say here? There are also more framing improvements in X7 regarding double frame walls etc. Please check it out. Link to comment Share on other sites More sharing options...
LeeDrafter Posted March 20, 2015 Share Posted March 20, 2015 Thanks all, I look forward to upgrading my software someday. In the meantime, I will edit the header it the framing detail. Or I can just add the appropriate amount of boards to my materials list when I actually order the lumber. Link to comment Share on other sites More sharing options...
