HumbleChief Posted November 22, 2023 Share Posted November 22, 2023 I've attached a pic of what I'm trying to duplicate and have a test plan file linked below where I used a pretty complex series of floor structures and air gaps and framing but there has to be an easier way? https://www.dropbox.com/scl/fi/nloivz0c2gm2ykyqk6lwd/RAISED-PLATFORM-1.plan?rlkey=xv2jizk1jp7e1zfbhdzei6xm9&dl=0 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 22, 2023 Share Posted November 22, 2023 Place a landing right on top of the floor and size it to your desired width, depth & height. 1 Link to comment Share on other sites More sharing options...
TeaTime Posted November 23, 2023 Share Posted November 23, 2023 On 11/22/2023 at 6:50 PM, HumbleChief said: but there has to be an easier way? Expand Does there? Two options come to mind immediately with this sort of thing: 1) Exactly what you did: Duplicate floor structure, add air gap. This is great because the cavity doesn't need to show on the plan, and the Relative Ceiling heights are totally functional. 2) Create that room on Floor 3. Shorten the cavity room on Floor 2. The downside is that obviously the cavity room shows on the floor 2 plan and the actual room is separated to Floor 3. Awkward. But it works. 1 Link to comment Share on other sites More sharing options...
glennw Posted November 23, 2023 Share Posted November 23, 2023 I haven't had a chance to look at your plan yet but a room with a Shelf Ceiling may work. 2 Link to comment Share on other sites More sharing options...
HumbleChief Posted November 27, 2023 Author Share Posted November 27, 2023 On 11/22/2023 at 8:41 PM, Joe_Carrick said: Place a landing right on top of the floor and size it to your desired width, depth & height. Expand Thanks Joe, that might work in the demo plan but the floor plan I'm trying to duplicate is very odd shaped and I need to spec the framing with more detail. Link to comment Share on other sites More sharing options...
HumbleChief Posted November 27, 2023 Author Share Posted November 27, 2023 On 11/23/2023 at 4:15 AM, glennw said: I haven't had a chance to look at your plan yet but a room with a Shelf Ceiling may work. Expand Thanks Glenn, can't find a way to get that to work as it's the entire room that needs the raised floor, not just room with the room. Link to comment Share on other sites More sharing options...
HumbleChief Posted November 27, 2023 Author Share Posted November 27, 2023 On 11/23/2023 at 12:28 AM, TeaTime said: Does there? Two options come to mind immediately with this sort of thing: 1) Exactly what you did: Duplicate floor structure, add air gap. This is great because the cavity doesn't need to show on the plan, and the Relative Ceiling heights are totally functional. 2) Create that room on Floor 3. Shorten the cavity room on Floor 2. The downside is that obviously the cavity room shows on the floor 2 plan and the actual room is separated to Floor 3. Awkward. But it works. Expand Thanks Tea, and I'm thinking since I've done the leg work on the real plan I should just stick with this idea. Link to comment Share on other sites More sharing options...
