DefinedDesign Posted November 14, 2023 Share Posted November 14, 2023 Hello! I'm using CA X12 and attempting to mock up a wall using soffits so I can detail how to attach different materials to an existing wall for the carpenters building stairs. My problem is the middle soffit goes floor to ceiling and I don't see settings to get rid of the baseboard molding. I've checked Ignore Room Moldings (Soffit Specification Box >General >Options) but the baseboard molding remains. I should also mention in the soffit specification box under moldings there are no moldings. Thanks in advance! Link to comment Share on other sites More sharing options...
DBCooper Posted November 14, 2023 Share Posted November 14, 2023 Rebuild 3D. Link to comment Share on other sites More sharing options...
DefinedDesign Posted November 14, 2023 Author Share Posted November 14, 2023 Just now, DBCooper said: Rebuild 3D. Thanks for the quick reply DBCooper unfortunately this doesn't correct the problem. Link to comment Share on other sites More sharing options...
TeaTime Posted November 14, 2023 Share Posted November 14, 2023 28 minutes ago, DefinedDesign said: I've unchecked Ignore Room Moldings (Soffit Specification Box >General >Options) but the baseboard molding remains Unless this somehow didn't work right in X12, that should do it. Maybe try lifting it 1/16" off the floor - if it's not ON the floor, it shouldn't pick up the floors' moldings. Still requires rebuilding 3D though - moldings don't redraw until that happens. Link to comment Share on other sites More sharing options...
Solution DBCooper Posted November 14, 2023 Solution Share Posted November 14, 2023 First, check "ignore room moldings" in the soffit dialog and then rebuild 3D should update the room moldings and they should ignore the soffit and not build around them.. The only reasons I can think that this wouldn't work is if your room moldings were converted into custom molding polylines or your soffit has a custom molding applied to it. If it's not one of these things, then post your plan. 1 Link to comment Share on other sites More sharing options...
DefinedDesign Posted November 14, 2023 Author Share Posted November 14, 2023 2 hours ago, TeaTime said: Unless this somehow didn't work right in X12, that should do it. Maybe try lifting it 1/16" off the floor - if it's not ON the floor, it shouldn't pick up the floors' moldings. Still requires rebuilding 3D though - moldings don't redraw until that happens. Most likely an X12 issue as none of the suggestions are working. I added 1/2 plywood over top of it to make it go away. Link to comment Share on other sites More sharing options...
DefinedDesign Posted November 14, 2023 Author Share Posted November 14, 2023 2 hours ago, DBCooper said: First, check "ignore room moldings" in the soffit dialog and then rebuild 3D should update the room moldings and they should ignore the soffit and not build around them.. The only reasons I can think that this wouldn't work is if your room moldings were converted into custom molding polylines or your soffit has a custom molding applied to it. If it's not one of these things, then post your plan. Thanks it doesn't work I suspect it is an X12 issue or a CA issue on a Macbook Pro. I added 1/2 plywood to make it disappear. Link to comment Share on other sites More sharing options...
DefinedDesign Posted November 14, 2023 Author Share Posted November 14, 2023 2 hours ago, DBCooper said: First, check "ignore room moldings" in the soffit dialog and then rebuild 3D should update the room moldings and they should ignore the soffit and not build around them.. The only reasons I can think that this wouldn't work is if your room moldings were converted into custom molding polylines or your soffit has a custom molding applied to it. If it's not one of these things, then post your plan. I literally stepped away from my laptop for an hour to take a neighbor to pick up their car and responded to your post that it won't work as I tried multiple times. So for kicks I try again and it works I didn't close my laptop, I just left it for an hour. Marking your answer as the solution, thanks! Link to comment Share on other sites More sharing options...
Kbird1 Posted November 15, 2023 Share Posted November 15, 2023 3 hours ago, DefinedDesign said: Thanks it doesn't work I suspect it is an X12 issue or a CA issue on a Macbook Pro. I added 1/2 plywood to make it disappear. If you don't need moldings ? I'd suggest you use 3D solids instead, and if moldings are need use a Molding Polyline for them. M. 1 Link to comment Share on other sites More sharing options...
