armfx89 Posted August 31, 2023 Share Posted August 31, 2023 I am modelling a house with low pitch roof ( 0.5/12). As far as i know, asphalt shingles don't work on such low pitch. Anyone knows the surface layers i can use for such roof? Thanks Link to comment Share on other sites More sharing options...
JKEdmo Posted August 31, 2023 Share Posted August 31, 2023 2 minutes ago, armfx89 said: Anyone knows the surface layers i can use for such roof You could go with a standing seam metal roof or a single-ply membrane roof such as TPO. Check with a roofer or roofing manufacturer to confirm the minimum slope required for the roofing product. Jim 1 Link to comment Share on other sites More sharing options...
Chrisb222 Posted August 31, 2023 Share Posted August 31, 2023 11 hours ago, armfx89 said: As far as i know, asphalt shingles don't work on such low pitch. You're right, shingles won't work. EPDM membrane can go down to 1/4"/foot 1 Link to comment Share on other sites More sharing options...
TCB_BdnMY Posted August 31, 2023 Share Posted August 31, 2023 I see your over in Calgary, I know here in MB there are a few different ways of going about this. Like JKEdmo said above, standing seam or TPO membrane are the most common. You can use other metal roofing types with some extra ice and water guard on the bottom edge of the roofline. What is the structure? There are also going to be different regulations depending on the application of the building, ie storage shed vs residential etc. Most pole sheds etc are just 24" truss spacing / 1x4 purlins / foil backed roll insulation / 20" pan Standing Seam roofing. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted September 1, 2023 Share Posted September 1, 2023 On 8/30/2023 at 8:26 PM, armfx89 said: Anyone knows the surface layers I can use for such roof? Peal and stick baby! Sheath the roof with OSB and tape the joints to seal them. Apply any flashing and drip edge: Seal the roof with the recommended sealant: Roll out the roofing material removing the covering on the adhesive backing as you go: Easy peasy, this is the stuff: GAF Liberty 3 ft. x 34 ft. (100 sq. ft.) SBS Self-Adhering Cap Sheet Roll for Low Slope Roofing in White Link to comment Share on other sites More sharing options...
Kbird1 Posted September 3, 2023 Share Posted September 3, 2023 As Rich pointed out P+S is pretty popular, but I prefer a 2 or 3 ply Roll Roofing (also call Torch On) product below 3 pitch. ( most shingle ManF. Warranty limit ) M. Link to comment Share on other sites More sharing options...
