Zoyvod Posted August 28, 2023 Share Posted August 28, 2023 Hi, does anyone know how to change the default label text for items e.g. headers in X15. I want the label for headers to be lintel's by default, so on a framing plan it will automatically say 45x140 x 900 mm Lintel x 2.. instead of headers. I don't want to go through every header label and change the text manually. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 28, 2023 Share Posted August 28, 2023 You will find lintel defaults in your window and door defaults in the Framing tab labeled as "Header Label Defaults". Link to comment Share on other sites More sharing options...
GeneDavis Posted August 28, 2023 Share Posted August 28, 2023 Headers are framing in Chief-speak, while lintels are trim. Are you wanting what Chief terms headers, called out in labels as "lintels" instead? Link to comment Share on other sites More sharing options...
Chrisb222 Posted August 28, 2023 Share Posted August 28, 2023 9 hours ago, Zoyvod said: Hi, does anyone know how to change the default label text for items e.g. headers in X15. I want the label for headers to be lintel's by default, so on a framing plan it will automatically say 45x140 x 900 mm Lintel x 2.. instead of headers. I don't want to go through every header label and change the text manually. Edit > Default Settings > Doors > Exterior Door On the Framing tab, click Header Label Defaults, enter whatever you want. Place new door, frame wall. Link to comment Share on other sites More sharing options...
GeneDavis Posted August 28, 2023 Share Posted August 28, 2023 Methinks the OP wants it auto-labeled. It's like Americans have names for things, hoods and trunks of cars come to mind, and the Brits call those bonnets and boots. Perhaps a feature request is needed, some kind of global terms replacement. Like, even in the specs and dialog tabs. Substitute "column" for "post," swap out "lookout" for "outrigger." How about other languages? Should there be a Japanese version of Chief? Link to comment Share on other sites More sharing options...
Chrisb222 Posted August 28, 2023 Share Posted August 28, 2023 10 minutes ago, GeneDavis said: Methinks the OP wants it auto-labeled. Yep, my post shows how to do that. 11 minutes ago, GeneDavis said: Perhaps a feature request is needed Why? It already exists. 1 Link to comment Share on other sites More sharing options...
