Joe_Carrick Posted August 19, 2023 Share Posted August 19, 2023 I have a project that the city is asking for more detailed MEP than I would normally provide. Do you have any consultants you use to do plumbing diagrams and electrical panel circuit layouts? Or, are there some standard details you use? Link to comment Share on other sites More sharing options...
VHampton Posted August 19, 2023 Share Posted August 19, 2023 Most states are now requiring HERS ratings. (Res-Check is becoming outdated to some degree. Especially on new builds.) The energy analysis by the rating provider involves fairly skilled technicians. Aside from insulation specifications, they can often provide a basic HVAC layout w/ equipment sizes. It’s worth looking into. Lighting and plumbing are still kept in the wheelhouse for most projects. These areas aren't nearly as complex as HVAC. Simple diagrams for permit applications typically gets the job done. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 21, 2023 Share Posted August 21, 2023 the builders I draw for have their subs provide me with the info. needed. they markup a plan, then I transfer that info. Doesn't happen very often, maybe 2 times in 10 years.. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 22, 2023 Share Posted August 22, 2023 On 8/18/2023 at 8:13 PM, Joe_Carrick said: I have a project that the city is asking for more detailed MEP than I would normally provide. Do you have any consultants you use to do plumbing diagrams and electrical panel circuit layouts? Or, are there some standard details you use? Joe, take a look at this stream I did today and mentioned you a few times: Link to comment Share on other sites More sharing options...
Bob_Medvetz Posted August 22, 2023 Share Posted August 22, 2023 Joe, Attached is the format that I use for Electric Service Panels. It is a Word document. Bob Medvetz Service Panel Example.pdf 1 Link to comment Share on other sites More sharing options...
