resdes Posted July 26, 2023 Share Posted July 26, 2023 When choosing the "full perspective view" on a floor plan and choosing the standard view, the materials do not show up. The "active layer display" used layers have been turned on but the materials/view do not show up. How do I correct this? Thank you. Link to comment Share on other sites More sharing options...
DBCooper Posted July 26, 2023 Share Posted July 26, 2023 Have the walls been marked as invisible? Are the walls using transparent materials? Are the walls on the normal walls layer? If it's not one of these, then you might want to post the plan. More thoughts: Does it happen in all plans, or just one plan? If it is just one plan, then you should post it. If it happens in all your plans, then it could be the result of a video card or driver problem. Link to comment Share on other sites More sharing options...
Gawdzira Posted July 26, 2023 Share Posted July 26, 2023 Is it a light-house? Link to comment Share on other sites More sharing options...
Dtrconstruction Posted July 28, 2023 Share Posted July 28, 2023 I hope you find the answer as I have the same problem after finally upgrading to x15 today. For me it seems only glass shows up. All files. EDIT: found the driver update for my graphics card from mfg. website and installed. Seems to be running proper again now. Link to comment Share on other sites More sharing options...
resdes Posted August 7, 2023 Author Share Posted August 7, 2023 On 7/26/2023 at 10:49 AM, DBCooper said: Have the walls been marked as invisible? Are the walls using transparent materials? Are the walls on the normal walls layer? If it's not one of these, then you might want to post the plan. More thoughts: Does it happen in all plans, or just one plan? If it is just one plan, then you should post it. If it happens in all your plans, then it could be the result of a video card or driver problem. Just like "Dtrconstruction" mentioned, this happened after I upgraded to X15. The walls are regular 2x6 walls, not invisible or transparent materials. This happens on all my floor plans. What do you mean "post the plan" Thank you. Link to comment Share on other sites More sharing options...
DBCooper Posted August 7, 2023 Share Posted August 7, 2023 "Post the plan" means attach a copy of the plan to your post so that someone else can download it and see if they have the same problem. You usually have to make a zip or archive version of the plan in order to attach it because this forum has limits on how big an attached file can be. Some times you need to remove extra stuff to try and make the plan file smaller so you can attach it. Some people prefer to put a link to a plan file on a cloud account when it is too big to post. In your case, I really suspect that it is just a video card or driver issue (like it turned out to be for DT). If all else fails, then you might want to contact tech support. Link to comment Share on other sites More sharing options...
DeLayDesign Posted August 8, 2023 Share Posted August 8, 2023 37 minutes ago, resdes said: Just like "Dtrconstruction" mentioned, this happened after I upgraded to X15. The walls are regular 2x6 walls, not invisible or transparent materials. This happens on all my floor plans. What do you mean "post the plan" Thank you. Could be a graphics card issue - although I'm not 100% certain. How old is your setup - is your graphic card up to date? Link to comment Share on other sites More sharing options...
TeaTime Posted August 8, 2023 Share Posted August 8, 2023 5 minutes ago, DeLayDesign said: Could be a graphics card issue I'd say it's rather probable that it is. https://www.chiefarchitect.com/support/article/KB-00106/troubleshooting-3d-camera-view-display-problems-in-chief-architect.html Link to comment Share on other sites More sharing options...
JordanATL Posted 9 hours ago Share Posted 9 hours ago On 7/26/2023 at 12:42 PM, resdes said: When choosing the "full perspective view" on a floor plan and choosing the standard view, the materials do not show up. The "active layer display" used layers have been turned on but the materials/view do not show up. How do I correct this? Thank you. I am having this exact same issue with my MacBook Pro. From what I see online, there’s no way for me to update the drivers? I’m fairly new at this and just purchased the software—have I made a huge mistake and it’s not going to be usable on my laptop? Link to comment Share on other sites More sharing options...
DBCooper Posted 8 hours ago Share Posted 8 hours ago Not sure about macs. Check the system requirements to see if your machine is supposed to work: https://www.chiefarchitect.com/products/sysreq.html If it does, then you should probably call tech support on Monday. Link to comment Share on other sites More sharing options...
