SHCanada2 Posted July 18, 2023 Share Posted July 18, 2023 trying for a 14" roof (12+2 overhang). CA looks like it will only do 24 as a min, or perhaps I am missing something? 48" overhang specified on the long wall dbx: 6" specified as overhang 694 Muirfield Cr - fe (2).zip Link to comment Share on other sites More sharing options...
rgardner Posted July 18, 2023 Share Posted July 18, 2023 Do you mean you are trying to use the auto roof feature of the wall setting but use manual roof planes? Change your roof plane settings. Link to comment Share on other sites More sharing options...
DBCooper Posted July 18, 2023 Share Posted July 18, 2023 Did you try playing with the "minimum alcove size" in the build roof dialog? Link to comment Share on other sites More sharing options...
SHCanada2 Posted July 18, 2023 Author Share Posted July 18, 2023 10 hours ago, rgardner said: Change your roof plane settings. trying to auto do it. doesnt seem to work 30 minutes ago, DBCooper said: Did you try playing with the "minimum alcove size" in the build roof dialog? just tried setting to 2". made no difference Link to comment Share on other sites More sharing options...
rgardner Posted July 18, 2023 Share Posted July 18, 2023 4 minutes ago, SHCanada2 said: trying to auto do it. doesnt seem to work In your picture you are placing a manual roof plane... Link to comment Share on other sites More sharing options...
SHCanada2 Posted July 18, 2023 Author Share Posted July 18, 2023 ? not sure what you mean I just highlighted it. i didnt draw it \..and if i try to delete it, it gives me the warning ...with aout rebuild turned on your changes will be lost Link to comment Share on other sites More sharing options...
rgardner Posted July 18, 2023 Share Posted July 18, 2023 Is this what you are trying to do? Auto roofs. Set room to 48" height to show it clearly. Will create a separate roof plane if you have the room height as the same. Link to comment Share on other sites More sharing options...
SHCanada2 Posted July 18, 2023 Author Share Posted July 18, 2023 interesting. my walls have basically the same settings, i changed my room height for the cant to be 48 to see if something would change, no change, still the 24" roof. I tried pulling the exterior wall right through instead of just breaking the exterior wall to a bump out, no difference. ...a little stumped Link to comment Share on other sites More sharing options...
rgardner Posted July 18, 2023 Share Posted July 18, 2023 3 hours ago, SHCanada2 said: interesting. my walls have basically the same settings, i changed my room height for the cant to be 48 to see if something would change, no change, still the 24" roof. I tried pulling the exterior wall right through instead of just breaking the exterior wall to a bump out, no difference. ...a little stumped post the plan. Link to comment Share on other sites More sharing options...
SHCanada2 Posted July 19, 2023 Author Share Posted July 19, 2023 its in the first post Link to comment Share on other sites More sharing options...
TeaTime Posted July 19, 2023 Share Posted July 19, 2023 Uncheck Same Eave Heights in the Build Roof dialog. Link to comment Share on other sites More sharing options...
SHCanada2 Posted July 22, 2023 Author Share Posted July 22, 2023 On 7/19/2023 at 8:56 AM, TeaTime said: Uncheck Same Eave Heights in the Build Roof dialog. the doc indicates: When Same Height Eaves is checked, any non-default overhang values specified in the Wall Specification dialog are used. Roof planes are raised or lowered so that the eave height is the same, regardless of the horizontal overhang. it worked, thanks you but not sure why. This is a 4; tall cantilever. if the "eave height" is to the distance from zero to bottom of eave, then by CA adding an extra 2' to the roof didnt actually make it same height to anything. i.e what eave is it matching to I suppose if "Eave height" means the distance from top plate to the bottom of the eave (or more likely the bottom of the fascia board), then it should change with the pitch. so i changed to a 4:12 and sure enough the eave is now 3' instead of 2' I would think though this setting should be on the wall and not global? otherwise if i have different pitched roofs on my top floor and I have this cantilever, it will not work for both Link to comment Share on other sites More sharing options...
