GeneDavis Posted June 17, 2023 Share Posted June 17, 2023 See my system specs in the sig line. I have tried installing other drivers, and all cause the fail which locks Chief and displays the message ending in "device will be removed." Which driver is working for you? Link to comment Share on other sites More sharing options...
GeneDavis Posted June 17, 2023 Author Share Posted June 17, 2023 Just crashed again. Attached is the message I got. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 17, 2023 Share Posted June 17, 2023 Give 531.61 a try. There are newer ones available but others seem to be happy with it. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 17, 2023 Share Posted June 17, 2023 52 minutes ago, Chopsaw said: Give 531.61 a try. There are newer ones available but others seem to be happy with it. These are working for me just fine...... I did have crashes earlier this week as described in a Client's Plan and Chief TS tracked it down to me turning on Auto (Roof) Framing and there was a tiny roof plane, barely big enough to see left behind, that chief couldn't Auto frame causing Device Removed Crashes and Lockups, which stopped completely after deleting the offending roof plane. M. Link to comment Share on other sites More sharing options...
DBCooper Posted June 17, 2023 Share Posted June 17, 2023 I guess the real question is, does this happen in all plans or just with one particular one? I think that if it happens in all plans, then it is probably a vide card problem. If it happens with just one plan, then it is probably something in the plan. Link to comment Share on other sites More sharing options...
