jerryajohnson35 Posted May 8, 2023 Share Posted May 8, 2023 Link to comment Share on other sites More sharing options...
joey_martin Posted May 8, 2023 Share Posted May 8, 2023 2 Link to comment Share on other sites More sharing options...
Solution TeaTime Posted May 8, 2023 Solution Share Posted May 8, 2023 Joey's on point - unless you want them mirrored on a SH, then that won't work. You'll need to use the Custom Muntin process to create two separate CAD Blocks, one per lite. 1 Link to comment Share on other sites More sharing options...
jerryajohnson35 Posted May 9, 2023 Author Share Posted May 9, 2023 thank yaw Link to comment Share on other sites More sharing options...
cjanderson66 Posted September 5, 2023 Share Posted September 5, 2023 I know that there are over 1300 toolbar buttons but can someone tell me where I can find the Load Muntin toolbar button. I have done a search and it does not show up at all and I cannot seem to find it anywhere. Link to comment Share on other sites More sharing options...
TeaTime Posted September 5, 2023 Share Posted September 5, 2023 Yo, it only shows up under the right conditions. Pull up Help or slap that F1 and search "Load Muntin", there's a topic that explains it all pretty well. Link to comment Share on other sites More sharing options...
cjanderson66 Posted September 5, 2023 Share Posted September 5, 2023 1 minute ago, TeaTime said: Yo, it only shows up under the right conditions. Pull up Help or slap that F1 and search "Load Muntin", there's a topic that explains it all pretty well. Yo TeaTime, I clicked on a window and created a line for a muntin on this window and then blocked it. Clicked the window and it does not show up at all. I looked at the Load Muntin help and that is what brought me to here. Link to comment Share on other sites More sharing options...
DBCooper Posted September 5, 2023 Share Posted September 5, 2023 So according to the help file (under "Custom Muntins"): Quote The CAD block should cover at least half the glass horizontally and one quarter of the area vertically, but should not overlap it in either direction by more than five percent. Nested CAD blocks cannot be used. I suspect that your one line cad block doesn't meet these conditions. 1 Link to comment Share on other sites More sharing options...
TeaTime Posted September 5, 2023 Share Posted September 5, 2023 15 minutes ago, solver said: Sometimes a bit of searching ... Maybe I'm just tired after a long tea-filled weekend but boy that comes off condescending to me, especially when 1 hour ago, cjanderson66 said: I have done a search A few things though, in that thread you stated "You can't block a single line" -- though yes, you certainly can. You just can't use a single line CAD Block to load custom muntins (**EDIT: in some situations - see below**) But you also weirdly glossed over @Alaskan_Son's perfectly viable and arguably much easier solution: Draw your CAD Line, place a text box, leave it empty and just hit OK, then select both the CAD Line and the empty Text box, Block, select window and Load Muntin. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted September 5, 2023 Share Posted September 5, 2023 BTW, you can block a single cad line. Just shift select it or marquee select it. Just sayin'. Still might not be able to use it for custom muntins unless it meets the area rules I posted above. Link to comment Share on other sites More sharing options...
TeaTime Posted September 5, 2023 Share Posted September 5, 2023 1 minute ago, TeaTime said: You just can't use a single line CAD Block to load custom muntins 1 minute ago, DBCooper said: unless it meets the area rules I posted above Oh, that's why. It's potentially rare that a single line will fulfil said criteria. Drew a diagonal line and it worked fine. I stand corrected amended. Link to comment Share on other sites More sharing options...
