Regandoc Posted April 22, 2023 Share Posted April 22, 2023 Hey, I am trying to figure out how to place a beam in between the 2 walls so that the roof over hang will not jut out like this. I am assuming i need to put a beam in here and then the roof will continue on the same plane as the rest of the roof?? but i can't figure out how to do this. Room divider does not work.. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 22, 2023 Share Posted April 22, 2023 Try adjusting the roof overhang in the Roof tab of the Wall DBX. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 22, 2023 Share Posted April 22, 2023 Ooops.. I just tried that and it did not work the way I expected it to. You may need to manually adjust the roof polyline. Link to comment Share on other sites More sharing options...
Regandoc Posted April 22, 2023 Author Share Posted April 22, 2023 Yeah didn't work for me as well. i have found this way that i can do it, but the problem is it creates separate rooms and hard to make it look great. but i guess there are worse things... Setting the part in yellow as no roof over top, then just extending the exterior wall and marking this section of invisible. Link to comment Share on other sites More sharing options...
glennw Posted April 22, 2023 Share Posted April 22, 2023 I don't think a beam by itself is not going to do anything There are a couple of ways I can think of to do this. Have a look at Extend Slope Downwards in the Roof Options in the Wall Specification dbx - you may need to raw an invisible wall. Have a look at Treat As Part of Bay/Box/Bow Window (with the Use Existing Roof option) at the bottom of the same panel. Do you want the bump out to have the same ceiling height as the main house, or lower (flat or sloping)? Link to comment Share on other sites More sharing options...
Regandoc Posted April 22, 2023 Author Share Posted April 22, 2023 I tried the Downwards slope and that didn't work either. I will play around with the bay/box/bow idea that might work. Well i will need to have a beam going from right to left to carry my roof truss's so i will have to have a dropped beam. so not to concerned about the ceiling height. Link to comment Share on other sites More sharing options...
DBCooper Posted April 23, 2023 Share Posted April 23, 2023 Roofs don't build to beams, they build to walls. One way to do this is to just move the bumpout wall so it is aligned with the other walls, build the roof, turn off auto rebuild roof, and then move the bumpout wall back out. Another way is to just edit the roof manually to line it up with the other parts. There are probably several other ways to do this but these two things above are probably the easiest. Link to comment Share on other sites More sharing options...
glennw Posted April 23, 2023 Share Posted April 23, 2023 1 hour ago, Regandoc said: I tried the Downwards slope and that didn't work either. That should work. Did you create a new room with an invisible wall where you want the beam to go? Did you make the 2 short return walls Full Gable? Did you rebuild the roof? Post the plan if you are still struggling. Link to comment Share on other sites More sharing options...
Regandoc Posted April 23, 2023 Author Share Posted April 23, 2023 I tried posting but the file is too big.. any suggestions? is there a different way to do it? Link to comment Share on other sites More sharing options...
Chopsaw Posted April 23, 2023 Share Posted April 23, 2023 5 minutes ago, Regandoc said: I tried posting but the file is too big.. any suggestions? is there a different way to do it? You can post a zip file for Glenn or a simplified version of your plan the exhibits the same issue. I can't get a logical setting to work though so my solution would be to use "Extend Slope Downwards" and then edit the roof polyline and don't leave any extra nodes. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted April 23, 2023 Share Posted April 23, 2023 Or if you want to keep things automated you can create a "Roof Baseline Polyline" and edit that. Link to comment Share on other sites More sharing options...
glennw Posted April 23, 2023 Share Posted April 23, 2023 This is all Auto using Extend Slope Downward. Is this what you want? Link to comment Share on other sites More sharing options...
Chopsaw Posted April 23, 2023 Share Posted April 23, 2023 17 minutes ago, glennw said: This is all Auto using Extend Slope Downward. Is this what you want? Any other settings involved there Glenn ?? It does not seem to work for me. Alcove perhaps ? Extend Slope does not seem to limit the overhang. Link to comment Share on other sites More sharing options...
glennw Posted April 23, 2023 Share Posted April 23, 2023 Chopsaw, Ignore my last few posts, with all my playing around I had inadvertently left Treat As Part OF...toggled on. I think that is the easiest way to go though. Make all the walls Hip Walls and Treat As Part Of Bay/Box/Bow Window. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted April 23, 2023 Share Posted April 23, 2023 7 hours ago, glennw said: Make all the walls Hip Walls and Treat As Part Of Bay/Box/Bow Window. Ok that does work. It seemed that it should but everything else needs to fall in line. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 23, 2023 Share Posted April 23, 2023 3 hours ago, Chopsaw said: Ok that does work. It seemed that it should but everything else needs to fall in line. it must definitely be all about the correct settings, if I try this in X15 ..... I am back to the extend slope downward Roof..... and if 1 try to match the OH manually ie set the OH to say 6" ( 24" OH on main roof , 18" bumpout ) Chief does all sorts of weird things (Pic 2) which I assume is to do with the new Heel Height for Trusses.... in another try it altered the main roof OH to 6 " all the way along too Just way easier to fix manually though I think extend slope downward should do better with bumpouts since that's what it's for.... Link to comment Share on other sites More sharing options...
Chopsaw Posted April 23, 2023 Share Posted April 23, 2023 2 minutes ago, Kbird1 said: Chief does all sorts of weird things So it does not seem to work at all in x15 ? Maybe I should have posted some of the crazy results in x14. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 23, 2023 Share Posted April 23, 2023 7 minutes ago, Chopsaw said: So it does not seem to work at all in x15 ? Maybe I should have posted some of the crazy results in x14. Sorry 1st pic above is with Suggested Settings, which is what extend slope gave me, but maybe I have something else on or off or ??? like Glenn did. M Link to comment Share on other sites More sharing options...
Regandoc Posted April 24, 2023 Author Share Posted April 24, 2023 Thanks for all the advice! i tried a bunch but the easiest was just to do it manually. Sometimes all the automation of the program does more hard then good haha, any of you know why my deck is not generating ? I built a deck below and it worked perfectly fine.. but i build it up above and everything goes wrong! haha 1 Link to comment Share on other sites More sharing options...
