northwoods1 Posted February 9, 2015 Share Posted February 9, 2015 Hello, I would like to know how to create a timber detail on the exterior gable of a house. Does anyone know how to do this? I attached a picture of what I am trying to create. Thanks. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 9, 2015 Share Posted February 9, 2015 You could start here - https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=timber+frame+chief+architect Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted February 9, 2015 Share Posted February 9, 2015 This type of detail can be done easily using p-solids. When adding the wood grain material you will probably have to copy the material and change the grain direction to conform with the angle of the timbers you make. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 9, 2015 Share Posted February 9, 2015 You can also create a truss there and modify it. Link to comment Share on other sites More sharing options...
northwoods1 Posted February 9, 2015 Author Share Posted February 9, 2015 Larry, I am some what new to chief, did you mean polyline solid by p-solid? Could you explain in a little more detail how you could achieve this? Thanks for all the responses everyone else. Link to comment Share on other sites More sharing options...
Gawdzira Posted February 9, 2015 Share Posted February 9, 2015 He did mean polyline solid. If you draw your solids in the elevation view it will be easy to manipulate them. Also, you can use the Make Parrellel tool to rotate the entire object to match your slope of the roof. Link to comment Share on other sites More sharing options...
