Why Am I Having Trouble With 3D Rendering?
michellejensen7
When I did an elevation or perspective, nothing would show up, just a white blank page.  I followed some instructions on the Chief Architect Support page and changed some of my rendering preferences and now I can see the elevations and perspectives but it still doesn't look quite right as lines are missing etc. I've gone to HP.com to update my driver but it says there are no available updates. Not really sure where to go from here..? Do I not have the right requirements? Do I need a new laptop or is it a simple fix?
Laptop I'm using- HP Pavilion dv6 Notebook PC, Windows 7, 64-bit, 8GB
Microprocessor- Intel® Core i7-2670QM CPU @ 2.20GHz
Graphics Device 1- Radeon HD 6770M
Graphics Device 2- Intel® HD Graphics Family
Any input would be great!
Michelle
right click on your desktop and look for a menu item referencing your video card.  You have to open it and
in one of the tabs it will have an option to associate it with certain programs.  These(my) instructions are general
you will have to work your way through what you see.
Michelle, in Preferences you can check which video card you are using. Radeon should have an app to choose with software programs use its card. You can also check to make sure your Intel driver is up to date; a good idea too for your Radeon driver.
Finally, you can force Chief to use one of the video cards by right clicking on Chief's icon and select your video card.
Here is an article from HP on this topic. I hope it helps.
http://support.hp.com/us-en/document/c03048374
Unfortunately 3D graphics and hardware have always been a weak link in computers. We work really hard to try to make them work right. In fact a couple of the guys were working really hard to try to find a solution to a problem with Intel graphics yesterday.
It is our desire to make every graphics card work as well as we can. Thanks for the information on your system it helps us to better understand the problems that you and likely many others are having.
    31591
    Tmbrstone
    Tmbrstone
  • Similar Content
    • By ericepv
      Floor plans and renderings from a Rochester, NY based company available for remote work. I am a long time Chief user (X6 to X14) and have worked for many commercial and residential clients across North America. You can view samples of my work on my website, Houzz profile  or my YouTube channel.
      Please contact me directly at 585-441-5291 EST or by email: eric@epvisualz.com.
    • By BlackDiamond
      I have over 8 years experience with Chief Architect (currently using X14) and have worked on various projects from simple starter homes to extravagant estates, multi-family projects, production homes, and resort communities. I currently live in Oklahoma but have worked remotely very successfully for many years. I would appreciate the opportunity to discuss with you how I might be of assistance on your next project. Please email me at blackdiamonddesign4@gmail.com.
      Valley concept.pdf
    • By basilbabaa
      SITUATION:  X13 3D renders, when compared to X12, appear blurred, washed out, less vibrant in quality and the vector renders have excessive line weights in X13
      Rather than hijack a previous topic thread, I am starting this topic as a result of a side conversation that emerged here-in:
      It appears that there are others experiencing this same issue, and so I thought I would begin this here in it's own topic thread.
      Here is a Dropbox link to image and video files (generated on both a i9 and M1 Pro Max chips) depicting the issue: https://www.dropbox.com/sh/9zt4tagbuhsfkbi/AABsTnIW6DjT5uExeP6e5mcAa?dl=0
      As a note, I have already opened a support case with Chief Technical Support and they have graciously offered to look into it:
      If anyone else is noticing lesser quality output with 3D rendering in X13 as compared to X12, perhaps we can share our experience and thoughts here as well as with support towards a workable solution.
    • By lashleydesign
      Hello All,
      My name is Lauren Brantley, I am located in the heart of Virginia I specialize in 3D visualization/rendering services.
      CLICK HERE to watch a video on my processes
      To know more about my services CLICK HERE
      I would love to connect on social as well you can find me @lashleydesign on all social networks.
    • By Arch_Tech
      Hello all,
      I am using CA X13.
      I am designing a house that has a wing that is at 45 degrees relative to the other wing of the house.  I am working with a Home builder and he has shown me that when a house is at 45 degrees, typically the elevation views reflect that by only showing the outline of the structure that is set at 45 degrees, like this.
      As you can see the garage portion is at 45 degrees relative to the elevation view.  I am pretty sure this set was produced with AutoCAD.
      How can I make this happen in CA?
      Thanks in advance!
