fromPOK Posted January 13, 2023 Share Posted January 13, 2023 Hello experts - I am new to CA. Using 14. Can you please help me why I can't see my window trim in this camera view? Link to comment Share on other sites More sharing options...
scottharris Posted January 13, 2023 Share Posted January 13, 2023 It looks like your layer for 'casing, interior' is turned off. See if that solves your issue. 1 Link to comment Share on other sites More sharing options...
fromPOK Posted January 13, 2023 Author Share Posted January 13, 2023 Scott, I have it on. Please look in 2nd pic Link to comment Share on other sites More sharing options...
rgardner Posted January 13, 2023 Share Posted January 13, 2023 1 hour ago, fromPOK said: Scott, I have it on. Please look in 2nd pic It looks like you have something funky going on with that window as the jamb is not set right it is not cutting the wall completely. Check to make sure that is set to fit to wall and see if it helps. Usually for this type of problem it is best to upload the file but that is not possible with the trial version I don't believe as you cannot save the file. Link to comment Share on other sites More sharing options...
DBCooper Posted January 13, 2023 Share Posted January 13, 2023 In your first picture, you are showing us what your window defaults are set to. My guess is that the window you are showing in your camera view is not set to match your defaults. BTW, only the casing sizes can be set to "use default" which makes them "dynamic defaults". The casing profile is not dynamic. This means that when you change your window defaults, any windows that are already in the plan can have their casing sizes update automatically but the profile won't. If you want to make the window in your plan match your defaults, you could just delete it and place a new one. You could also open it up and modify it manually. There are a number of other ways to do this but since you are new, I won't confuse you by going into them all. Link to comment Share on other sites More sharing options...
scottharris Posted January 14, 2023 Share Posted January 14, 2023 If you are still seeing issues, I suggest reaching out to our tech department for a solution. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted February 15, 2023 Share Posted February 15, 2023 What Scott told you, you show windows specifications settings in there casing is ON but look at the layers on the left they could be off and casing will not show. Link to comment Share on other sites More sharing options...
