SHCanada2 Posted December 11, 2022 Share Posted December 11, 2022 There is light coming through the jamb at left and at top Roof is there. backdrop intensity is 250. I lowered the exposure to 0.3 if i change the door is goes away setting is "sun follows camera" any ideas on how to fix? thanks Link to comment Share on other sites More sharing options...
Chopsaw Posted December 11, 2022 Share Posted December 11, 2022 Those E21 Craftsman doors are from the library. Are the glass panels from the library or parametric ? Possibly parametric doors fit the opening differently. If so try the F01 Link to comment Share on other sites More sharing options...
SHCanada2 Posted December 11, 2022 Author Share Posted December 11, 2022 Stock doors, I'll try the other thanks Link to comment Share on other sites More sharing options...
robdyck Posted December 11, 2022 Share Posted December 11, 2022 If you zoom in closely in a section view, you will see that Chief's door produce a gap between the door and the jamb. Manufacturer library doors do not produce that gap. 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted December 11, 2022 Author Share Posted December 11, 2022 F01 is much better. I will log a ticket as the default should be working 52 minutes ago, robdyck said: Chief's door produce a gap between the door and the jamb you would think they would have a profiled jamb to stop the door when it shuts f01: 1 Link to comment Share on other sites More sharing options...
glennw Posted December 12, 2022 Share Posted December 12, 2022 10 hours ago, SHCanada2 said: you would think they would have a profiled jamb to stop the door when it shuts I have requested custom door jamb profiles previously. Please send in a suggestion if it is something you would like to see. Link to comment Share on other sites More sharing options...
