Doug_N Posted November 28, 2022 Share Posted November 28, 2022 I know this has come up before somewhere, but for the life of me, searches don't seem to find the topic. When a window mimics the roof pitch (can be done in the window DBX) you get a window with a top slope mimicking the roof slope. So far so good. Not so much for doors. Because the door is made of a door symbol and a door frame assembly the door frame can get adjusted but not the door itself. The door ends up sticking out through the sloping part of the frame and ends up exposed, sometimes over the roof. (This is particularly true of doors under stairs) Does anyone know how to actually make a door that slopes like the frame? Link to comment Share on other sites More sharing options...
JacobB Posted November 28, 2022 Share Posted November 28, 2022 Use a parametric door type or custom symbol. 1 Link to comment Share on other sites More sharing options...
Chrisb222 Posted November 28, 2022 Share Posted November 28, 2022 Only works if you use one of the parametric door styles, not a library symbol. Link to comment Share on other sites More sharing options...
Doug_N Posted November 28, 2022 Author Share Posted November 28, 2022 4 minutes ago, Chrisb222 said: Only works if you use one of the parametric door styles, not a library symbol. Parametric door styles??? Where can I find those? Link to comment Share on other sites More sharing options...
Chopsaw Posted November 28, 2022 Share Posted November 28, 2022 10 minutes ago, Doug_N said: Parametric door styles??? Where can I find those? Any style option in the door dbx other than "Library" or Default if you have that set to use a Library door. 1 Link to comment Share on other sites More sharing options...
Solution Chrisb222 Posted November 28, 2022 Solution Share Posted November 28, 2022 8 minutes ago, Doug_N said: Parametric door styles??? Where can I find those? Not much to choose from: There was a suggestion recently asking for more control of parametric doors. You can "fake" a center bar(s) using a glass panel style, setting the number of lites, and making the glass panes a solid material, but it's very limited: Link to comment Share on other sites More sharing options...
Doug_N Posted November 28, 2022 Author Share Posted November 28, 2022 Aha!!! Thanks guys!!! Brilliant! Link to comment Share on other sites More sharing options...
DBCooper Posted November 29, 2022 Share Posted November 29, 2022 Quote You can "fake" a center bar(s) using a glass panel style, setting the number of lites, and making the glass panes a solid material, but it's very limited: That is pretty clever. I bet you could create even more door styles using custom muntins for your stiles and rails. Link to comment Share on other sites More sharing options...
