Cabinet is partially cutting out of view + How to hide removed wall outline in view
MovingandShaking
Hi Team, I'd appreciate your help solving a couple of problems:
Software: Chief Architect Premier X13
Topic 1: Base cabinet is being partially cut from view
Topic 2: This is a remodel--the removed wall has been hidden from view but the walls, floor and ceiling are still showing the outline of the wall.
Thanks for your help!
Your invisible wall is the problem. Either as DB said above: remove the offending invisible wall or move the invisible wall outside of the edge of your cabinet run so it does not interfere with your cabinets display. If you can delete the invisible wall, then that is another alternative provided that action does not interfere with your cabinet wall elevations details.
