Chris50 Posted September 28, 2022 Share Posted September 28, 2022 Hello everyone, I use version 8 and I am wanting to know how to use either cable or tube railing for stair railing. Can anyone help me out with this. I have a modern home and this is all that is holding me up. Any help would be appreciated. Thanks, Chris Link to comment Share on other sites More sharing options...
Chris50 Posted September 28, 2022 Author Share Posted September 28, 2022 x8 Link to comment Share on other sites More sharing options...
Chris50 Posted September 28, 2022 Author Share Posted September 28, 2022 Anyone?? Link to comment Share on other sites More sharing options...
Chris50 Posted September 28, 2022 Author Share Posted September 28, 2022 When I use tube railing it shows up as little pieces of tube and it is in the wrong direction. ??? Link to comment Share on other sites More sharing options...
DBCooper Posted September 28, 2022 Share Posted September 28, 2022 I don't think you can, at least not very easily. You might be able to create it manually using molding p-lines. You might be able to create a symbol out of a cable railing used as a fence that is sloped. You might be able to fake it using some other techniques as well. You also might want to think about upgrading because this is pretty easy in X14: https://www.chiefarchitect.com/support/article/KB-01029/specifying-glass-cable-or-decorative-railing-panels.html Link to comment Share on other sites More sharing options...
Chris50 Posted September 28, 2022 Author Share Posted September 28, 2022 Eric, do you have a solution for my problem?? Link to comment Share on other sites More sharing options...
Chris50 Posted September 28, 2022 Author Share Posted September 28, 2022 Yes, I know I need to upgrade, just not an option at the moment, extremely busy producing plans. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 28, 2022 Share Posted September 28, 2022 Chris, I just opened my X8 and it works EXACTLY the same as in X14: you turn off "Rails, left and right" in the stair dialog. Then you draw a railing wall on each edge of the stair object you wish to have rails. You then program the rails to whatever style you wish. Open the railing specification dialog of each railing wall, go to its "Rail Style" tab and select at the bottom "Follow Stairs". If the result is not visually correct moving the railing walls with your arrow key until they do display properly will then produce the visual results you wish. I just did this in my X8 so I know what I am talking about. DJP Link to comment Share on other sites More sharing options...
ericepv Posted September 28, 2022 Share Posted September 28, 2022 Be sure you specify 'Panels' for your railing and then select cable railings from the library. Link to comment Share on other sites More sharing options...
VHampton Posted September 28, 2022 Share Posted September 28, 2022 If I recall correctly, one can make symbols in X-8. In a new plan, per DB, one could presumably make a "panel" by drawing poly-lines with the appropriate spacing. Create a symbol while in 3D mode. Then utilize the new railing 'panel' per DJP's example. Link to comment Share on other sites More sharing options...
