ChipW-Am Posted September 26, 2022 Share Posted September 26, 2022 I'd like to know if CA can do this (so far I've failed at getting it to work correctly) -- a very steep hillside, small lot, house that has about 3/4 of it inside the hillside (completely enveloped by the hillside as if it were a cave). When I try to do this in CA I end up with an empty space around the structure where the terrain doesn't clip it. How do I get the terrain to actually hit up against the exterior walls? Link to comment Share on other sites More sharing options...
rlackore Posted September 26, 2022 Share Posted September 26, 2022 Turn off Hide Terrain Intersected by Building. 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 26, 2022 Share Posted September 26, 2022 Of course you can using Chief. In terms of real help here, you need to post some images or ideally a copy of your plan file so others can really help, in detail. DJP Link to comment Share on other sites More sharing options...
ChipW-Am Posted September 26, 2022 Author Share Posted September 26, 2022 rlackore Posted 1 hour ago Turn off Hide Terrain Intersected by Building. If I turn that off then the terrain flows into/through the house. I also created a terrain hole to the exact size of the exterior walls but that doesn't help. Attached are two images of the concept. In the first you can see the sky between the house and the terrain. The terrain needs to completely envelope the house up to where it curves down. The hill side is much higher and steeper, I've truncated it quite a lot for the initial work. The roof style has not yet been decided, at this point is all just conceptual. Link to comment Share on other sites More sharing options...
rlackore Posted September 26, 2022 Share Posted September 26, 2022 The terrain hole modifies the terrain above and below, as you've noted, so it may not help with an earth home that is partially buried. AFAIK, Chief doesn't have a terrain feature that can create a horizontal recess in a terrain perimeter. Some creative possibilities may include polyline solids, molding polylines, etc. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 26, 2022 Share Posted September 26, 2022 Terrain holes do NOT "alter the terrain" other than making a hole UNLESS they are programmed by the end user to do so. As I see it now you just need to make the hole smaller to reduce the reveal of the front of the house structure so it reveals only as much as needed to poke through the terrain. DJP Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 26, 2022 Share Posted September 26, 2022 If you want the "Terrain" to cover a part of the roof - you'll need to model the terrain as a solid and then cut a hole in that using boolean substraction. It won't actually be Chief's Terrain - but it will allow the hole to be like a horizontal tunnel into the hillside rather than a vertical shaft. The other option would be to model the terrain above the residence as a solid. Either way, you're going to need to learn how to create and modify solids. It would really be useful to know what version of the software you're using. Link to comment Share on other sites More sharing options...
glennw Posted September 26, 2022 Share Posted September 26, 2022 Yes, it can be done using a Terrain and a Terrain Hole. 2 2 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 26, 2022 Share Posted September 26, 2022 Clever Glenn Link to comment Share on other sites More sharing options...
ChipW-Am Posted September 27, 2022 Author Share Posted September 27, 2022 Thanks for all the suggestions, I'm gonna see if I can replicate what Glenn suggests. Link to comment Share on other sites More sharing options...
