1st floor room with no floor
Jeffcrigler
Go to solution Solved by Jeffcrigler,
I agree with Eric, that is not a good solution.
My guess is that if you checked "default" for your floor finish and your floor structure, that this might actually fix the problem.  If not, then you should really post the plan and I bet someone could figure out in a few minutes what is wrong without all of the guess work.
