Scharp Posted September 11, 2022 Share Posted September 11, 2022 I am using X13. In room specifications, when I change a room height, all the other variable change as well. Is there a way to lock the different heights? I am perplexed why the computer changes my desired heights Link to comment Share on other sites More sharing options...
Scharp Posted September 12, 2022 Author Share Posted September 12, 2022 I dont know how to do screen captures. I believe my post is very clear. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 12, 2022 Share Posted September 12, 2022 2 hours ago, Scharp said: I dont know how to do screen captures. I believe my post is very clear. Use either of the Window's Snipping Tools , and you can post the capture straight into the Reply area here on the Forum 1 hour ago, solver said: 8 hours ago, Scharp said: I am perplexed why the computer changes my desired heights Because they are all related. Correct...... but you may need to explain a bit more precisely what you are changing and why you think they shouldn't change......as there is no way to Lock certain heights in the Room DBX due to them all being related. M. Link to comment Share on other sites More sharing options...
OldBarnDesign Posted September 12, 2022 Share Posted September 12, 2022 10 hours ago, Scharp said: I dont know how to do screen captures. I believe my post is very clear. In Windows you can press the PrintScn button and it will copy the screen to the clipboard. Then open Paint or any other image program and hit Ctrl-V. As Solver said, all those fields are related so changing one number affects the others. Rough Ceiling is the height of the ceiling from the floor to the ceiling joists. Finished Ceiling should be slightly lower (5/8" by default) because it includes the drywall. If you change the rough ceiling height, it obviously affects the height of the drywall and vice versa. Hitting the Help button within the dialog will explain it. Link to comment Share on other sites More sharing options...
joey_martin Posted September 12, 2022 Share Posted September 12, 2022 If you have a room above the room you are changing the height of, Chief will adjust the entire floor. For instance you can't raise the ceiling height of a living room if there are rooms above it, especially if the rooms are separated by an interior wall. Does that sound like your situation? Link to comment Share on other sites More sharing options...
Scharp Posted September 12, 2022 Author Share Posted September 12, 2022 Not really. I draw the first floor. Then hit build foundation. I want my stem wall at 37 1/2 and the ceiling height to be 109 1/8”. If I change any height, the other values will automatically change, even though I dont want them to. Saying they are related is of no help. I should, in my opinion be able to control what each value states. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 12, 2022 Share Posted September 12, 2022 You still aren't saying or better showing us what Height you are changing ...and why, so we really can't help explain things better for you sorry. M. Link to comment Share on other sites More sharing options...
joey_martin Posted September 12, 2022 Share Posted September 12, 2022 Go to the foundation level to make the change to the stem wall, or even better open the default setting and make sure the foundation is set to that height and you won't have to worry about it any longer. Link to comment Share on other sites More sharing options...
DBCooper Posted September 12, 2022 Share Posted September 12, 2022 Try these: https://www.chiefarchitect.com/videos/#playlist-88 Also, if you click on the "help" button on the room structure panel, it will explain the controls a little bit better. Link to comment Share on other sites More sharing options...
