weverett50 Posted September 1, 2022 Share Posted September 1, 2022 Most houses I design are pueblo style which have varying heights of parapets. When I have a variation in height, the edge of the wall shows framing rather than stucco. These extra lines mess up the elevation views as well as when I show the customer in 3d. Anyone have a remedy for this? Thank you! Link to comment Share on other sites More sharing options...
rgardner Posted September 1, 2022 Share Posted September 1, 2022 2 hours ago, weverett50 said: Most houses I design are pueblo style which have varying heights of parapets. When I have a variation in height, the edge of the wall shows framing rather than stucco. These extra lines mess up the elevation views as well as when I show the customer in 3d. Anyone have a remedy for this? Thank you! Most common methods would be using: Moldings Wall Caps But you can also use: 3d Solids Roof Planes Ceiling Planes Cabinets hmmm probably forgetting about 20-30 other methods that are more creative.. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 1, 2022 Share Posted September 1, 2022 Wall Layers Edit Tool perhaps? M. Link to comment Share on other sites More sharing options...
rgardner Posted September 1, 2022 Share Posted September 1, 2022 1 hour ago, Kbird1 said: Wall Layers Edit Tool perhaps? M. I believe the OP has broken the wall and manually adjusted it. Link to comment Share on other sites More sharing options...
glennw Posted September 1, 2022 Share Posted September 1, 2022 Can you post a picture of your wall definition dbx? Is your stucco wall layer a main layer? If so, make it an exterior layer. Link to comment Share on other sites More sharing options...
robdyck Posted September 2, 2022 Share Posted September 2, 2022 If the stucco is an exterior layer, Chief should wrap it around the edge. However, for a parapet wall, you could use a pony wall and a different wall type for the upper portion that has stucco on both interior and exterior (or a waterproofing layer on the interior). Or, you can edit the parapet walls on the attic level. That's how this was done, and I used a wall cap molding for the top. View from on the roof: 1 Link to comment Share on other sites More sharing options...
