Stairs from garage to basement
Jambruins
You created the railing wall using an interior 4 wall, and you set the garage floor to -24 1/2 " but your stairwell room's floor is set to Zero inches,  thus the wall type reveal. When you change the wall type to better match the garage floor to "Concrete Stem Wall" and set the floor height settings to match you get a better looking result, try it and see.
I have made a few changes to your plan and used a pony wall for the railing side as well as some changes to the stair materials, top height and materials.  I would suggest a landing and door at the bottom of the stairs because most building codes require some "gas tight" provisions to prevent gas fumes from entering the living portion of the building.Gadway House DN_2022_07_31.plan
16 minutes ago, Jambruins said:
Doug,  I can't open your file because you created it with a newer version of chief architect.  Can you save it down to version 12?
Sorry I can't.  I am on vacation right now and using my laptop which only has x-14 installed.
