DGail1 Posted July 21, 2022 Share Posted July 21, 2022 Is there any way to specify drawer/door front dimensions in the cabinet specifications? I'm using x14, which finally shows door and drawer front heights & widths, but doesn't allow you to set those. I've adjusted item heights, separation heights, even used blank areas to "fudge" the results but I can't get all the fronts to the sizes my cabinet maker uses. 30" cabinet box, frameless construction. I need 5 15/16", 11 15/16, 11 15/16 with 1/8" reveal between fronts. I can get 2 out of 3 drawer fronts right, but nothing I've tried will allow me to get the 3rd one right. Any suggestions? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 21, 2022 Share Posted July 21, 2022 Try adjusting the toekick height and/or countertop height or thickness. You need to have the cabinet itself (not including the toekick) exactly 1/2" more than the sum of the drawers. Link to comment Share on other sites More sharing options...
MarkMc Posted July 21, 2022 Share Posted July 21, 2022 48 minutes ago, DGail1 said: 30" cabinet box, frameless construction. I need 5 15/16", 11 15/16, 11 15/16 with 1/8" reveal between fronts. That adds up to 30 1/16" is a part of the reason Even than- to get those faces you have no reveal at the bottom (have had makers do that) AND no reveal at the top which I've never seen and would never ever allow. Something is off?? Link to comment Share on other sites More sharing options...
rgardner Posted July 21, 2022 Share Posted July 21, 2022 Pay attention to the box that says "Front Height:" Link to comment Share on other sites More sharing options...
Kbird1 Posted July 22, 2022 Share Posted July 22, 2022 3 hours ago, DGail1 said: 30" cabinet box, frameless construction. I need 5 15/16", 11 15/16, 11 15/16 with 1/8" reveal between fronts. I can get 2 out of 3 drawer fronts right, but nothing I've tried will allow me to get the 3rd one right. Are you sure the box isn't actually 30 1/4" sitting on a 4 1/2" Kick to allow for 3cm ( 1 1/4") Quartz Counters? for the standard 36" height ? Link to comment Share on other sites More sharing options...
DGail1 Posted July 22, 2022 Author Share Posted July 22, 2022 Definitely 30" box, 4 1/2" toe kick, 1 1/4 counter = 35 3/4" total height. Sorry Joe, those can't be changed However, thanks Markmc for pointing out my math error...that's what happens when I pull all-nighters. I double checked with my cabinet maker...7/8 instead of 15/16...and it works! I think I've got it licked now, thanks to everyone for your help! Sometimes it just takes another perspective to be able to see more clearly. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 22, 2022 Share Posted July 22, 2022 49 minutes ago, DGail1 said: Sorry Joe, those can't be changed That's what you get with stock cabinets. I use a company that is much more flexible in their sizes. OTOH, I never have to specify the door or drawer sizes. The Cabinet Manufacturer does it automatically even when I specify odd sizes down to 1/16" increments. Link to comment Share on other sites More sharing options...
