Framing Schedule Issue.
ACADuser
There is a 2 stage process that will locate the wall in plan - but not the framing member.
This may get you close enough:
Select the header in the schedule.
On the Edit menu, select Find Object In Plan.
The wall detail will open with the header selected.
Select Find Wall on the Edit menu.
This will take you back to a plan view with the wall containing the header selected.
