Weird Line Tail
buildology
Have a look in Preferences> CAD> Line Properties> Endcap Printed Length:   Mine is set at 1/32" if that helps but you are likely using a Metric template.  Maybe .8 mm or round it off to 1 mm
  On 5/2/2022 at 12:59 AM, buildology said:
Second question for the day..
When I turn on Line Weights it scales the lines styles to 50 times bigger. I have the line weight set to 1.
Is there away to stop that happening?
Expand
Are you talking about the Preferences Setting for minimum Line Weight or you set the line Weight to 1?
Line Weights are generally controlled by the Layer they are on.....
Expand
I'm talking about the line style spacing, both line in the image are the same line but when I turn the Line weight on and off it changes the spacing for some reason. It should only change the width not the spacing.
I have both Layer Weight and the Line Specification set to 1.
Expand
No. Line weights "on" shows the dash the way it will print. Line weights "off" changes that. Just the way it is.
