Treehouse2339 Posted April 27, 2022 Share Posted April 27, 2022 When I am in camera mode exterior, I see the inside and outside lighting but when I go to Ray Trace the lights are all off. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 27, 2022 Share Posted April 27, 2022 Make sure on the Light Data Tab the box is Checked for Raytrace as well or "Both" Link to comment Share on other sites More sharing options...
Treehouse2339 Posted April 27, 2022 Author Share Posted April 27, 2022 Kbird, I know that it must be a setting issue. I have both checked. In camera view the inside lights show as on and the outside lights are off and the Raytrace show both as off. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 27, 2022 Share Posted April 27, 2022 3 hours ago, Treehouse2339 said: Kbird, I know that it must be a setting issue. I have both checked. In camera view the inside lights show as on and the outside lights are off and the Raytrace show both as off. I can't remember which version we got UNLIMITED Lights in........... X12 and Up for sure , but before that Chief had an (artificial) OpenGL Light limit of 8 , so you may have to pick and choose which ones are "ON" as I see you have X11. However Chief Still defaults the No# of Lights to 8, have a look in X11 if you have this DBX, in my template plan I have set it to 200 to avoid this in most situations..... Link to comment Share on other sites More sharing options...
Treehouse2339 Posted April 27, 2022 Author Share Posted April 27, 2022 I am using X14. I have mine set for 40. This little plan only has 6 outside and 8 inside lights. Cameras were set for 20 and I changed them all to 200. Still a puzzle. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 28, 2022 Share Posted April 28, 2022 3 hours ago, Treehouse2339 said: I am using X14. Then please change your Signature so people don't waste their time.... M. Link to comment Share on other sites More sharing options...
rgardner Posted April 28, 2022 Share Posted April 28, 2022 3 hours ago, Treehouse2339 said: I am using X14. I have mine set for 40. This little plan only has 6 outside and 8 inside lights. Cameras were set for 20 and I changed them all to 200. Still a puzzle. Any chance one of those lights was actually a rope light? Oob they are set to have a light every 3” so if you have rope light for example above some crown molding 50’ by itself will eat up 200 lights. You have a chandelier with 8-10 bulbs? 1 Link to comment Share on other sites More sharing options...
Treehouse2339 Posted April 28, 2022 Author Share Posted April 28, 2022 Its a large barn area that has hanging fixtures inside and wall sconces on the outside. No chandelier. Link to comment Share on other sites More sharing options...
Treehouse2339 Posted April 28, 2022 Author Share Posted April 28, 2022 Kbird i am sorry for that. Link to comment Share on other sites More sharing options...
MarkMc Posted April 28, 2022 Share Posted April 28, 2022 Interior lights don't show in PBR in X12, 13 or 14 or RTRT. Just the way it is, don't know why. To show lit interior from exterior you need to use It works with CPU RT but for PBR see Kbirds post below (I think I knew that once upon a time but well, CRS is getting worse . 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted April 28, 2022 Share Posted April 28, 2022 The is a difference in PBR when you use the Automatic Setting and when you use the "Default Light Set " , Chief has always "balanced" Interior Lights with the Sun Lumen Setting too , so it is not always easy to figure out the issue with a particular View. Sometimes as in the Recessed lights below required me to turn One on and off to Active them all once the Default Set was active. sometime Lighting is wrong too if looking from one room to another as Chief uses the "Room" ie looking from a Family Room back into the Kitchen in an open Plan House. These examples are in a test plan in X14, I just poked my head through the wall for the interior snips.... Automatic Default Set On 2 Link to comment Share on other sites More sharing options...
Treehouse2339 Posted April 29, 2022 Author Share Posted April 29, 2022 K bird, Genius! Thank you!!! Link to comment Share on other sites More sharing options...
Kbird1 Posted April 29, 2022 Share Posted April 29, 2022 5 minutes ago, Treehouse2339 said: K bird, Genius! Thank you!!! You're Welcome No Pics? No proof means it didn't happen M. Link to comment Share on other sites More sharing options...
