See angles while moving
SDeckB
When drawing or rotating objects, the angle is usually displayed in the status bar.  If you setup your allowed angles, it will be easier to snap to some angle that is not on 15 degree or 7.5 degree increments.
Placing an angular dimension (as shown above) is a good way of specifying an exact angle.  You could also use the transform/replicate dialog.
The make parallel tool can also be very useful.  One thing that some people don't know is that you can click on the tool a second time to open the dialog that allows you to choose whether or not the whole object is rotated or just the current line.
