Changing Cabinetry hardware positions
Designers_Edge
Go to solution Solved by ericepv,
  • 1 year later...
Is there a way to change the direction to a door on multiple cabinets at once? I have a drawer pull (horizontal orientation) I am replacing on multiple doors and the edit option becomes grayed out if I try to edit multiple cabinets at a time.
Make a style palette set to only change hardware. The one I show was done for wall cabinets so won't affect base or tall.
You could add either or both of those to the existing style palette if you have a cabinet set with correct options to use to create the palette.
NOTE- the style palette will work on individual cabinets with just a click, scoping does not always work by "room" but does work by floor.
First clear all then select only these- I haven't checked but it may (very likely) be possible to leave out the Main Door Handle Style to use a different style already in a plan
  • 2 weeks later...
