HStone Posted February 4, 2022 Share Posted February 4, 2022 I am drawing a 3 story structure with vertical board and batten siding. The boards do not line up vertically between floors. What can I do to fix this? Thanks Link to comment Share on other sites More sharing options...
HStone Posted February 4, 2022 Author Share Posted February 4, 2022 BTW, this is a round, silo-like structure... Link to comment Share on other sites More sharing options...
robdyck Posted February 4, 2022 Share Posted February 4, 2022 Use material regions. It will probably end up being faster then constantly editing the material patterns. Link to comment Share on other sites More sharing options...
HStone Posted February 5, 2022 Author Share Posted February 5, 2022 I used line drawing as it shows the problem most clearly. Thanks, Henry Link to comment Share on other sites More sharing options...
glennw Posted February 5, 2022 Share Posted February 5, 2022 Try ....Define Material dbx>Pattern>Offset and Angle>Global Symbol Mapping If that doesn't work, you may have to make copies of the material (one for each floor) and change the horizontal offset for each floor. Link to comment Share on other sites More sharing options...
CharlesVolz Posted February 6, 2022 Share Posted February 6, 2022 12 hours ago, HStone said: I used line drawing as it shows the problem most clearly. Post the plan Henry and someone will find a trick. Link to comment Share on other sites More sharing options...
HStone Posted February 6, 2022 Author Share Posted February 6, 2022 Actually X13... Hi Charles; The program tells me the file is too big. Any suggestion on how to post it? Thanks, Henry Link to comment Share on other sites More sharing options...
HStone Posted February 6, 2022 Author Share Posted February 6, 2022 Thanks. Will do. H Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 6, 2022 Share Posted February 6, 2022 You might also try using a WALL TYPE that has a layer of 2x1 framing on the outside. It will actually add a level of realism. 1 Link to comment Share on other sites More sharing options...
HStone Posted February 6, 2022 Author Share Posted February 6, 2022 Thanks all; Here is DBox link to the file if anybody feels like taking a look. (Very complicated - for me - existing building)... https://www.dropbox.com/s/1a0yj4vezctahz9/Proposed 1_27_22.plan?dl=0 Thanks all, H Link to comment Share on other sites More sharing options...
