robdyck Posted November 28, 2021 Share Posted November 28, 2021 None of my angle walls are showing mitered corners. I thought I'd check to see if it's working correctly for others before I send this to Tech Support. Link to comment Share on other sites More sharing options...
GeneDavis Posted November 28, 2021 Share Posted November 28, 2021 Does it miter the 90 degree ones? Some might call that a miter. Link to comment Share on other sites More sharing options...
rgardner Posted November 28, 2021 Share Posted November 28, 2021 Looks like a bug to me. Depends on the angle (150 deg framed miterd) but this is what I got: Link to comment Share on other sites More sharing options...
Kiwideziner Posted November 28, 2021 Share Posted November 28, 2021 Maybe that is CA's terminology, I get the same result as everyone else. I notice that for angles that join up when mitred ends selected if that is not selected they dont even join. Link to comment Share on other sites More sharing options...
robdyck Posted November 29, 2021 Author Share Posted November 29, 2021 From Help: Mitre Ends of Angle Walls Specify how wall corners that are not right angles are framed. 90° corners are not affected by these settings. Select Mitre Plate Ends to mitre the ends of the top and bottom plates. If unchecked, top and bottom plates will be butted together. Select Rotate End Studs to rotate the studs closest to mitre ends to the angle of the mitre. If unchecked, studs will remain perpendicular to the angle of the walls. Select Horizontal Frame Thru to frame through the horizontal walls in plan view, butting vertical walls against them. If unchecked, walls that are vertical in plan view will frame through. Link to comment Share on other sites More sharing options...
