How would you create floor to ceiling banisters?
jp26jp
If you want precision, i.e., 3 per tread and all spaced evenly, the only way to control it is with solids.  You can do it with the framing, but you'll probably need to edit the framing to get that precision.  Solids go quickly, and you can use the move-edit tool to go really fast, using pitch and run as the move.  There's probably a way to use a distribution path if you are going the whole way with Chief's capabilities.
