jp26jp Posted October 2, 2021 Share Posted October 2, 2021 I'm wanting to create something like this, but I'm not quite sure where I'd even start. Any suggestions would be greatly appreciated. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 2, 2021 Share Posted October 2, 2021 If you use an auto railing it would push way up into the next level but if that does not matter then go ahead and us the DBX settings to do it otherwise use polyline solids and place them manually. Link to comment Share on other sites More sharing options...
rgardner Posted October 3, 2021 Share Posted October 3, 2021 You can Create a single layer wall type with Framing 4.5" o.c.+/- Link to comment Share on other sites More sharing options...
rgardner Posted October 3, 2021 Share Posted October 3, 2021 12 minutes ago, rgardner said: You can Create a single layer wall type with Framing 4.5" o.c.+/- Link to comment Share on other sites More sharing options...
Kbird1 Posted October 3, 2021 Share Posted October 3, 2021 38 minutes ago, rgardner said: I have used this method before as well , few quirks but works okay. Mick. Link to comment Share on other sites More sharing options...
GeneDavis Posted October 3, 2021 Share Posted October 3, 2021 If you want precision, i.e., 3 per tread and all spaced evenly, the only way to control it is with solids. You can do it with the framing, but you'll probably need to edit the framing to get that precision. Solids go quickly, and you can use the move-edit tool to go really fast, using pitch and run as the move. There's probably a way to use a distribution path if you are going the whole way with Chief's capabilities. Link to comment Share on other sites More sharing options...
