ACADuser Posted August 18, 2021 Share Posted August 18, 2021 The Doctor is very interesting in the plan development and doesn't want to see the extra line in plan view om his multi million dollar house. As a surgeon his is very picky. Chief says the only way to make it go away is to have the balcony floor at the same height as the interior. That's not going to happen. Any clever ways to deal with this? I'm preparing to use a solid fill poly with invisible border. Link to comment Share on other sites More sharing options...
rgardner Posted August 18, 2021 Share Posted August 18, 2021 Change the line style for that wall type? Link to comment Share on other sites More sharing options...
Chrisb222 Posted August 18, 2021 Share Posted August 18, 2021 Unfortunately, line display controls for railings don't work like they do for walls I typically turn railings display off and draw cad lines to get the look I want for plan views Link to comment Share on other sites More sharing options...
richoffan Posted August 19, 2021 Share Posted August 19, 2021 I have a CAD line in my layers called CAD, Whiteout... set to about 25 it covers most "unwanted" lines and can always be increased if need be. Handy to block a cross as well for those pesky dimension extensions that cross. Just copy paste on the intersection. Link to comment Share on other sites More sharing options...
ACADuser Posted August 19, 2021 Author Share Posted August 19, 2021 Both good suggestions. I have never tried the wide wipe-out line. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 19, 2021 Share Posted August 19, 2021 10 hours ago, ACADuser said: Both good suggestions. I have never tried the wide wipe-out line. Could you remove the Lines in Layout if needed ? maybe not possible with this though ? M. Link to comment Share on other sites More sharing options...
