SMB2021 Posted August 11, 2021 Share Posted August 11, 2021 In X13 it now automatically clips cabinet countertop overhangs when they butt against an appliance. Is there a workaround for this feature? While it's fine for against ranges or regular refrigerators, it also happens for under the counter refrigerators too. Even if the height is 34" or less it still clips it. Link to comment Share on other sites More sharing options...
Dermot Posted August 11, 2021 Share Posted August 11, 2021 Please post a plan that demonstrates the problem or even better, report this to our technical support team. Link to comment Share on other sites More sharing options...
SMB2021 Posted August 11, 2021 Author Share Posted August 11, 2021 Counter Clip Example.plan Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted August 11, 2021 Solution Share Posted August 11, 2021 Open Symbol>Options>Options>Type>change this to something else like maybe Refrigerators (built-in). I do however agree that this shouldn't happen when an appliance doesn't actually come in contact with the countertop. Make sure to send this in to tech support if you care enough to see it fixed/changed. Link to comment Share on other sites More sharing options...
robdyck Posted August 11, 2021 Share Posted August 11, 2021 Link to comment Share on other sites More sharing options...
Dermot Posted August 12, 2021 Share Posted August 12, 2021 I agree with Michael that if the appliance is lower than the counter top that it probably should not affect the counter top overhang. It is almost always best to report these kinds of problems directly to our technical support team so that it gets on the todo list. In this case, I think the easiest way to solve your problem is to just convert that counter top into a custom one and then drag it over the refer and up to the wall. This assumes that you want it under the counter top. If not, you can still just create a custom counter top and avoid the automatic behavior. Anytime the automatic counter tops aren't giving you what you need, you can usually just use a custom counter top instead. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted August 12, 2021 Share Posted August 12, 2021 It appears the old trick of making uneven countertop overhangs to go over a Built-in Fridge or Dishwasher no longer works either.... Link to comment Share on other sites More sharing options...
