GeneDavis Posted July 28, 2021 Share Posted July 28, 2021 I am struggling with some imprecise, or rather precise-but-not-imperial, CAD and dimensions. I draw a square in CAD and specify the sides as 9' 6.6006239531". The number comes from me trying to define the foundation for an octagonal porch whose long dimesion is exactly 16'-7 15/16". But that is a digression. Here is the issue. When I throw dimensions on that nine-foot-six-somenting square, the left to right number comes out as 9'-6 9/16" and the vertical one as 9'-6 5/8". Now we all have calculators and know that 9/16 is 0.5625 and 5/8 is 0.625, which means Chief rounded DOWN to get the horizontal dim, and UP to get the vertical, but why the inconsistency? Link to comment Share on other sites More sharing options...
rgardner Posted July 28, 2021 Share Posted July 28, 2021 Do you have grid snapping on? If you are needing to be that precise as far as the plans you may want to adjust your smallest dimension available to 1/16" Link to comment Share on other sites More sharing options...
Kbird1 Posted July 28, 2021 Share Posted July 28, 2021 It maybe relate to Grid Rounding ( preferences ) there have been several Threads in the past about it, and IIRC Chopsaw had a few ideas/theories on it ... Mick. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 29, 2021 Share Posted July 29, 2021 It's the result of Chief's Grid Rounding behavior. I don't have the time or inclination to explain it at the moment, but it's working as designed. The unexpected dimension being displayed is simply the result of where that dimension segment happens to land on the rounding grid. Either change to Distance Rounding in your Dimension Defaults or change the rounding accuracy for that dimension. Link to comment Share on other sites More sharing options...
GeneDavis Posted July 29, 2021 Author Share Posted July 29, 2021 Thanks. Didn't know I had that option for the single dimension. I will do that to increase my training level, after I delete the text patch I did over the numbers. Link to comment Share on other sites More sharing options...
